Forum Topic - Problems on LCD display function: (2 Items)
  I have one problem about LCD display.
I was using the beagle board with Dell S2009W LCD monitor.
The HDMI in beagle board is connected to DVI in Dell monitor.
I use the following parameters to control the display functions.
1. In beagle board BSP, the file \src\hardware\devg\omap35xx\omap35xx.conf has the setting in the below:
“hsw=20,hfp=128,hbp=64,vsw=4,vfp=24,vbp=24,ivs=1,ihs=1,ipc=1,ieo=0x4,acb=0,acbi=0,pcd=0x4,ppl=800,lpp=480,irq=25,
disptype=0,lcdfmt=0x1,verbose=1,hcursor=0,cached_mem=1,cache_flush=0”
2. In beagle board BSP, the file \src\hardware\startup\boards\omap3530\beagle.build has the display setting in the
following:
/etc/system/config/omap35xx.conf=omap35xx.conf
/etc/system/config/display.conf={
device \{
       drivername=omap35xx
        vid=0
        did=0
       modeopts=/etc/system/config/omap35xx.conf
        display \{
              xres=800
              yres=480
              refresh=60
              pixel_format=rgb565
              photon \{
                  enabled=1
                  xoffset=0
                  yoffset=0
                  cursor=software
                  input_group=1
  Now the above settings can display the UI(User Interface) picture generated by our software in Dell S2009W with the
resolution 800 * 480. But I can not change the resolution (800 * 480 is used now) anymore even if I change the
parameters in omap35xx.conf.
  I am confused now that the files omap35xx.conf and beagle.build seem to be unable to control the LCD display.
  Is there any files need to be modified in the BSP source codes for LCD display? Or how to modify the parameters in
both files correctly?
  If the display control is not a problem, other LCD monitors can be used to connect with the beagle board. Is it right
  Now the BSP source code is from the file “bsp-nto641-ti-omap3530-beagle-trunk.zip”.
  Please give me any clues that can solve this problem. Thanks!
RE: Problems on LCD display function
See response to your post in general-bsp forum.
Sent: July 15, 2010 11:49 AM
To: photon-graphics
Subject: Problems on LCD display function
"hsw=20,hfp=128,hbp=64,vsw=4,vfp=24,vbp=24,ivs=1,ihs=1,ipc=1,ieo=0x4,acb
disptype=0,lcdfmt=0x1,verbose=1,hcursor=0,cached_mem=1,cache_flush=0"
setting in the
following:
device \{
       drivername=omap35xx
        vid=0
        did=0
        display \{
              xres=800
              yres=480
              refresh=60
              pixel_format=rgb565
              photon \{
                  enabled=1
                  xoffset=0
                  yoffset=0
                  cursor=software
                  input_group=1
generated by our software in Dell S2009W with the resolution 800 * 480.
if I change the parameters in omap35xx.conf.
display? Or how to modify the parameters in both files correctly?
used to connect with the beagle board. Is it right ?
"bsp-nto641-ti-omap3530-beagle-trunk.zip".
Photon microGUI
http://community.qnx.com/sf/go/post59544
