Forum Topic - New Font Causes Double Spacing:
It has been a long time since I added any fonts.  I am trying to add a new font with a ttf file, but I keep getting
double spacing on the characters.  Has anyone had this problem?
RE: New Font Causes Double Spacing
Photon version?
From: Ronald Mich [mailto:community-noreply@qnx.com]
Sent: Friday, March 05, 2010 3:36 PM
To: photon-graphics
Subject: New Font Causes Double Spacing
new font with a ttf file, but I keep getting double spacing on the
Photon microGUI
http://community.qnx.com/sf/go/post48945
Re: RE: New Font Causes Double Spacing
Using Neutrino 6.3.2, but I am not sure what version of Photon it is.
RE: RE: New Font Causes Double Spacing
Ok, so you just copied the font to /usr/photon/font_repository?
If so, can you check /etc/system/config/font-traplist and see if you
have a entry for your font file?  If so, please post the font-traplist.
Sent: Friday, March 05, 2010 3:48 PM
To: photon-graphics
Subject: Re: RE: New Font Causes Double Spacing
Photon microGUI
http://community.qnx.com/sf/go/post48947
Re: RE: RE: New Font Causes Double Spacing
Yes, I added it to the font repository.  But there is only a crtc-settings file in /etc/system/config, there is no font-
traplist.
RE: RE: RE: New Font Causes Double Spacing
Have you restarted the system since adding it?
If not, please do so.  After that, please post:
/usr/photon/font_repository/font*
I suspect the metrics are not "correct", but I just want to make sure it
has not been mis-identified as monospace, versus proportional.
-Derek
Sent: Friday, March 05, 2010 4:26 PM
To: photon-graphics
Subject: Re: RE: RE: New Font Causes Double Spacing
crtc-settings file in /etc/system/config, there is no font-traplist.
Photon microGUI
http://community.qnx.com/sf/go/post48949
Re: RE: RE: RE: New Font Causes Double Spacing
Still No font-traplist, but attached is the contents of font_repository.
Attachment: Compressed file font_repository.zip 634.67 KB
RE: RE: RE: RE: New Font Causes Double Spacing
Oh, sorry Ronald, I thought this was a "dev" system, it's a target ...
that's why there is no font-traplist ... anyhow, all the config entries
appear in the fontdir, so that is fine ... stay tuned.
Sent: Monday, March 08, 2010 10:38 AM
To: photon-graphics
Subject: Re: RE: RE: RE: New Font Causes Double Spacing
Photon microGUI
http://community.qnx.com/sf/go/post49022
btw, is it the FreeSans one you are having troubles with?
To: photon-graphics
Photon microGUI
Re: RE: RE: RE: RE: New Font Causes Double Spacing
Yes, FreeSans. Thanks
Hi Ronald,
FreeSans,0@freesans_.ttf,ARIAL,0,,0020-F002,f,79x170,556K
FreeSansb,0@freesansbold_.ttf,Arial,0,B,0020-F002,f,79x170,277K
Notice that 'f' there, the font subsystem identified it as 'fixed-width'
in 632.  I do recall an issue with this, which seems to be corrected on
64x, as it identifies it as 'proportional'.  You can fake it out by just
changing that 'f' to a 'p'.
Just to cover all the bases, we ran these fonts through a validater, and
I hate to be the bearer of bad news, but these fonts are "bad".  There
are many glyphs that contain erroneous parameters, and bad bounding
boxes.  The rasterizer used by the font sub-system is built for speed,
and especially after initialization, does not check for all errors.
What I am trying to say is these fonts will corrupt memory over time, if
not in short order.  I suggest getting them fixed, or obtaining higher
quality fonts.
Kind Regards,
-Derek
To: photon-graphics
Photon microGUI
Thanks, that did work.  Thanks for the tip also.  I am trying to find a higher quality font.
