Forum Topic - Problems viewing images with pv: (4 Items)
Photon installation on my embedded sh7780 target seems to work well - I can start ped, shelf and other applications. I
cannot view files with pv or use bkgdmgr, however.
Here is my session
# Welcome to QNX Neutrino on HiCO.SH7780
# uname -a
QNX localhost 6.4.1 2009/05/20-17:34:08EDT hico7780 shle
# photon
# # <photon up and running ok>
# DL_DEBUG=1 pv /usr/photon/images/example.jpg
load_object: attempt load of libAp.so.3
load_elf32: loaded lib at addr 78200000(text) 7820efa0(data)
load_object: attempt load of libph.so.3
load_elf32: loaded lib at addr 78210000(text) 78304390(data)
load_object: attempt load of libm.so.2
load_elf32: loaded lib at addr 78310000(text) 7833aa20(data)
load_object: attempt load of libphexlib.so.3
load_elf32: loaded lib at addr 78340000(text) 7836e810(data)
load_object: attempt load of libimg.so.1
load_elf32: loaded lib at addr 7836f000(text) 7837dcc0(data)
load_object: attempt load of libfont.so.1
load_elf32: loaded lib at addr 7837e000(text) 78385060(data)
dlopen("PtHook.so",0)
load_object: attempt load of PtHook.so
load_elf32: loaded lib at addr 7830c000(text) 7830d710(data)
dlsym(0x8052000,_btext)=0x8042580
Library loaded; type 'add-sym pt_multihook.so 0x8042580' in gdb to load symbols
dlsym(0x8052000,PtHook)=0x7830c51c
# #< ctrl-C >
# sloginfo
Jan 01 00:00:00    5    14     0 tcpip starting
Jan 01 00:00:00    3    14     0 Using pseudo random generator.  See "random" option
Jan 01 00:00:15    1     8     0 phfont.so: init...
Jan 01 00:00:15    1     8     0 phfont.so: initialized.
Jan 01 00:00:15    1     8     0 phfont.so: '/dev/phfont[<32|64>]' server installed.
Jan 01 00:00:15    6     8     0 pci_init: found PCI device 126f:501
Jan 01 00:02:03    5     5     0 RegionSet(): rid=62 not found
Jan 01 00:02:03    5     5     0 RegionSet(): rid=42 not found
pv starts and shows an error window with text "Unable to load example.jpg file"
The example.jpg is a simple image from our web site (I have also tried different images).
What do the "RegionSet(): rid=42 not found..." mean? Am I maybe missing some resources on the target?
BTW: On linux I always use 'strace -e open <program>' in situations like this. Is there a similiar way to get a trace of
 all resources which a given process tries to open on QNX? I'm aware of the dtrace project, but it probably won't yet
work on SH architecture.
 - Martin
RE: Problems viewing images with pv
Hmm ...
Do you have:
/etc/system/config/img.conf
/lib/dll/img_codec_*.so
From: Martin Nylund [mailto:community-noreply@qnx.com]
Sent: Friday, November 27, 2009 8:46 AM
To: photon-graphics
Subject: Problems viewing images with pv
can start ped, shelf and other applications. I cannot view files with pv
Here is my session
# uname -a
# photon
symbols
# #< ctrl-C >
# sloginfo
"random" option
server installed.
example.jpg file"
different images).
this. Is there a similiar way to get a trace of all resources which a
it probably won't yet work on SH architecture.
 - Martin
Photon microGUI
http://community.qnx.com/sf/go/post42725
Re: RE: Problems viewing images with pv
I do have the libraries
# ls /lib/dll/img_codec_*
/lib/dll/img_codec_bmp.so              /lib/dll/img_codec_png.so
/lib/dll/img_codec_gif.so              /lib/dll/img_codec_sgi.so
/lib/dll/img_codec_jpg.so              /lib/dll/img_codec_tga.so
/lib/dll/img_codec_pcx.so
but the img.conf was missing. After copying /opt/qnx641/target/qnx6/etc/system/config/img.conf to my root filesystem I
am able to view images.
Thanks!
RE: RE: Problems viewing images with pv
Great! :)
Sent: Friday, November 27, 2009 9:43 AM
To: photon-graphics
Subject: Re: RE: Problems viewing images with pv
I am able to view images.
Thanks!
Photon microGUI
http://community.qnx.com/sf/go/post42737
