Forum Topic - Problem with trace bar in PtMTrends:
In my application I'm using PtMTrends and I'm facing a problem with it.
While I'm plotting a graph, when I place/ click the mouse pointer over the trace bar, the graph plotting slows down and
if the pointer is moved/ released the waveform appears disturbed for a short portion but it get backs to nomral.
This causes distorted waveform and slows the down the plotting. I tried disabling the flag Pt_selectable, Pt_cosume
events and also by enabling pt_blocked flags. The efforts were in vain.
How to overcome this?
Thanks in advance,
Lakshminarayanan.R
Re: Problem with trace bar in PtMTrends
Are you using a software mouse pointer? If you do, try switching to H/W.
RE: Problem with trace bar in PtMTrends
I'm not quite sure what you mean by switching to S/W / H/W mouse pointer! I have a PS/2 mouse connected to my target and
 I'm using devi-hirun driver for interfacing it with photon.
Adding more input, I have a touch screen on my target and the same behavior is observed if I touch the trace bar in the
screen. All I need is to block the interaction with this trend.
Thanks!
From: Misha Nefedov [mailto:community-noreply@qnx.com]
Sent: Monday, November 09, 2009 8:02 PM
To: photon-graphics
Subject: Re: Problem with trace bar in PtMTrends
Photon microGUI
http://community.qnx.com/sf/go/post41603
DISCLAIMER:
The contents of this e-mail and any attachment(s) are confidential and intended for the named recipient(s) only.
It shall not attach any liability on the originator or HCL or its affiliates. Any views or opinions presented in
this email are solely those of the author and may not necessarily reflect the opinions of HCL or its affiliates.
Any form of reproduction, dissemination, copying, disclosure, modification, distribution and / or publication of
this message without the prior written consent of the author of this e-mail is strictly prohibited. If you have
received this email in error please delete it and notify the sender immediately. Before opening any mail and
attachments please check them for viruses and defect.
Re: RE: Problem with trace bar in PtMTrends
What video driver are you using ?
RE: RE: Problem with trace bar in PtMTrends
I'm using svga driver.
From: Mike Gorchak [mailto:community-noreply@qnx.com]
Sent: Tuesday, November 10, 2009 3:10 PM
To: photon-graphics
Subject: Re: RE: Problem with trace bar in PtMTrends
Photon microGUI
http://community.qnx.com/sf/go/post41682
DISCLAIMER:
Re: RE: RE: Problem with trace bar in PtMTrends
svga driver provides software cursor only, so mouse flickering can't be fixed.
RE: RE: RE: Problem with trace bar in PtMTrends
We do not require the mouse at all in our system since we are going to use only touch screen. In that case is there any
solution?
Sent: Tuesday, November 10, 2009 4:20 PM
To: photon-graphics
Subject: Re: RE: RE: Problem with trace bar in PtMTrends
Photon microGUI
http://community.qnx.com/sf/go/post41685
DISCLAIMER:
Re: RE: RE: RE: Problem with trace bar in PtMTrends
Disable it completely -- in phgrafx set cursor to 'none'.
RE: RE: RE: RE: Problem with trace bar in PtMTrends
Thanks Misha, the problem is now solved. I have modified the cursor to none in my display configuration file.
Sent: Tuesday, November 10, 2009 7:59 PM
To: photon-graphics
Subject: Re: RE: RE: RE: Problem with trace bar in PtMTrends
Photon microGUI
http://community.qnx.com/sf/go/post41707
DISCLAIMER:
You shouldn't use the SVGA driver. It is only meant for testing purposes, I do not recommend it for a commercially
shipped system. What graphics controller are you using? Maybe there is a native graphics driver for it, or you could ask
 QNX to write one for you as part of a Custom Engineering contract.
- Malte
