Forum Topic - Initial texture parameters do not conforms to OpenGL ES 1.0 specification!: (3 Items)
Quote from OpenGL ES 1.0 specification:
"The initial value of GL_TEXTURE_MAG_FILTER is GL_LINEAR."
Software renderer conforms to this sentence, but hardware renderer which is provided by devg-extreme2 driver uses
GL_NEAREST as initial value of GL_TEXTURE_MAG_FILTER, which is wrong.
Maybe GL_TEXTURE_MIN_FILTER parameter must be checked too.
Re: Initial texture parameters do not conforms to OpenGL ES 1.0 specification!
Looks like problem is deeper than it appears: GL_TEXTURE_MIN_FILTER affect GL_TEXTURE_MAG_FILTER on devg-extreme2.
Magnification filter became the same as minimization filter.
Ok, looking at the source, min_filter is initialized to be:
GL_NEAREST_MIPMAP_LINEAR
and mag_filter is:
GL_LINEAR
I seen you second response here, and maybe there is corruption in the driver, and an "off by 1" indexing issue ...
-Derek
