Forum Topic - the LCD color is not as config:
in my test file, the layer format is GF_FORMAT_PACK_RGB565 ,code as below,
x=400;
y=240;
gf_context_set_fgcolor( context, 0x0000FF);//blue
gf_draw_rect(context,(width>>1)-1-x,(height>>1)-1-y,(width>>1)-1+x,(height>>1)-1+y);
x>>=1;
y>>=1;
gf_context_set_fgcolor( context, 0x00FF00);//?
x>>=1;
y>>=1;
gf_context_set_fgcolor( context, 0xFF0000);//green
x>>=1;
y>>=1;
gf_context_set_fgcolor(context,0xFFFFFF);//while
x>>=1;
y>>=1;
gf_context_set_fgcolor(context,0x000000);//black
in gf.h file:
/* Generic color represenation. Unless otherwise noted, this type is packed
 * native endian with the following components:
 * - Blue; 8-bit value occupying byte 0 (LSB)
 * - Green; 8-bit value occupying byte 1
 * - Red; 8-bit value occupying byte 2
 * - Alpha; 8-bit value occupying byte 3 (MSB). 255 = opaque, 0 = transparent */
byte0(0x0000ff) is blue, byte1(0x00ff00) is cambridge blue,byte2(0xff0000) is green......which is not right
coreesponding to defination of gf.h, what is the matter? thansk
Re: the LCD color is not as config
the surface format is PKLE_RGB565
RE: the LCD color is not as config
The GF code below looks ok for color.    Are you able to do any tests outside of GF to validate your hardware platform?
 It may be you have a different color mapping and need to adjust your display controller settings to map the colors
accordingly.
From: gong mingyu [mailto:community-noreply@qnx.com]
Sent: July 24, 2009 1:39 AM
To: advanced-graphics
Subject: the LCD color is not as config
x=400;
y=240;
x>>=1;
y>>=1;
x>>=1;
y>>=1;
x>>=1;
y>>=1;
x>>=1;
y>>=1;
in gf.h file:
Advanced Graphics
http://community.qnx.com/sf/go/post34484
Re: RE: the LCD color is not as config
now in the display.conf, pixel_format=rgb565 ;while in imx31.conf, the dispalay output pixel format ofmt = 18, the the
right color output.
 I can not understand the config, if rgb565, the ofmt should be 16, but this configure made wrong color output, byte0(
2009-07-28
mygong
发件人: Michael Van Reenen
发送时间: 2009-07-28  06:07:32
收件人: advanced-graphics
抄送:
主题: RE: the LCD color is not as config
accordingly.
x=400;
y=240;
x>>=1;
y>>=1;
x>>=1;
y>>=1;
x>>=1;
y>>=1;
x>>=1;
y>>=1;
in gf.h file:
Advanced Graphics
Advanced Graphics
http://community.qnx.com/sf/go/post34676
RE: RE: the LCD color is not as config
The ofmt option is the format of the iMX31 output to the physical LCD.  In your case it is 18 bits.   This is
independent of the pixel format selected in display.conf.  The iMX31 will convert the framebuffer data to the required
output format for the LCD.
Sent: July 27, 2009 11:16 PM
Subject: Re: RE: the LCD color is not as config
right color output.
2009-07-28
mygong
抄送:
accordingly.
x=400;
y=240;
x>>=1;
y>>=1;
x>>=1;
y>>=1;
x>>=1;
y>>=1;
x>>=1;
y>>=1;
in gf.h file:
Advanced Graphics
Advanced Graphics
Advanced Graphics
http://community.qnx.com/sf/go/post34681
Re: RE: RE: the LCD color is not as config
thanks!
2009-07-29
mygong
发送时间: 2009-07-28  19:48:26
抄送:
主题: RE: RE: the LCD color is not as config
right color output.
2009-07-28
mygong
抄送:
accordingly.
x=400;
y=240;
x>>=1;
y>>=1;
x>>=1;
y>>=1;
x>>=1;
y>>=1;
x>>=1;
y>>=1;
in gf.h file:
Advanced Graphics
Advanced Graphics
Advanced Graphics
Advanced Graphics
http://community.qnx.com/sf/go/post34695
