Re: Problems with Fujitsu Carmine eval board
04/16/2009 4:08 AM
post27169
dealing with the resolution issue, my best guess is your carmine.conf file does not match your display.conf file. This
is alluded to vaguely in the documenation for devg-carmine.so:
You can edit the configuration file to enable devg-carmine.so to run on your board. Follow the editing instructions in
the sample file, /usr/photon/config/carmine.conf, to specify the correct configuration for the required display mode.
(For a more detailed explanation of the display settings, see the appropriate Fujitsu documentation.)
and ...
Resolution and refresh support
Display size (pixels): Refresh rate (Hz): Color depth (bits per pixel):
640x480 60 15, 32
800x600 60 15, 32
1024x768 60 15, 32
Restrictions:
You can use the configuration file to specify other resolutions and refresh rates.
but it is more clear in the usemsg:
use -i devg-carmine.so
Graphics driver for Fujitsu Carmine Graphics Controller
The file "carmine.conf" can be used to customize hardware-related
settings for the devg-carmine.so graphics driver.
carmine.conf contains comments which describe the various settings
which may be configured.
The path the carmine.conf is specified via the "modeopts" device option
in the io-display configuration file, display.conf.
The X resolution and Y resolution specified via the xres and yres
options to io-graphics must match the 'hdp' and 'vdp' settings in
the carmine.conf file, respectively.
Hopefully this gets you going,
-Derek
