Forum Topic - QNX 6.6 touch screen setup:
Hello.
I'm trying to use touch screen at QNX 6.6.
I've searched and followed answers and then I'm seeing calib-touch screen now.
But I can't move the cursor or click.
After launching below programs in rc.local, calib-touch program could be run.
But touch doesn't work and cannot calibrate.
With QNX 6.5 touch screen works fine.
Does anyone have any idea what's wrong?
Thanks.
Launch at rc.local:
io-usb -duhci -dohci -dehci
io-hid -dusb -degalax
devi-hid kbd touch
drm-intel &
screen &
Here is hidview result:
# hidview
Device Address       : 0
Vendor               : 0x0eef (eGalax Inc.)
Product              : 0x0001
Version              : r1.10
Usage                : Pointer
Device Address       : 1
Vendor               : 0x045e (Microsoft)
Product              : 0x0752 (Wired Keyboard 400)
Version              : r1.10
Usage                : Keyboard
And this is my env variables:
# env
_=/usr/bin/env
SSH_CONNECTION=192.168.100.118 64713 192.168.100.177 22
PATH=/sbin:/usr/sbin:/usr/bin:/bin:/usr/sbin:/sbin:/usr/local/bin:/opt/bin:/opt/sbin:/bin:/sbin:/usr/bin:/usr/sbin
SHELL=/bin/sh
TMPDIR=/tmp
HOSTNAME=localhost
USER=root
PROCESSOR=x86
MAIL=/var/spool/mail/root
LD_LIBRARY_PATH=/prob/boot:/lib:/usr/lib:/lib/dll:/opt/qt5/lib:/opt/qnx6/x86/lib:/opt/qnx6/x86/usr/lib:/opt/qnx6/x86/lib
/dll:/usr/lib/graphics/intel-drm:/opt/qt5/plugins/platforms
QT_DEBUG_PLUGINS=1
HOME=/root
SSH_CLIENT=192.168.100.118 64713 22
QNX_HOST=/
QT_QPA_PLATFORM=qnx:no-fullscreen
QNX_TARGET=/
GRAPHICS_ROOT=/usr/lib/graphics/intel-drm
QQNX_PHYSICAL_SCREEN_SIZE=200,117
TERM=xterm
QML_IMPORT_PATH=/opt/qt5/imports
QML2_IMPORT_PATH=/opt/qt5/qml
QT_PLUGIN_PATH=/opt/qt5/plugins
FONTCONFIG_FILE=/etc/fontconfig/local.conf
QNX_CONFIGURATION=/etc/qnx
SSH_TTY=/dev/ttyp0
SYSNAME=nto
LOGNAME=root
This is my /usr/lib/graphics/intel-drm/graphics.conf:
begin khronos
  begin egl display 1
    egl-dlls = libEGL-mesa.so
    glesv1-dlls = libglapi-mesa.so libGLESv1_CM-mesa.so
    glesv2-dlls = libglapi-mesa.so libGLESv2-mesa.so
  end egl display
  begin wfd device 1
    wfd-dlls = libwfdcfg-sample.so libWFDintel-drm.so
    # Run "drm-probe-displays" to list the available displays and pipelines,
    # and "use $GRAPHICS_ROOT/libWFDintel-drm.so" for more information on
    # these driver-specific settings.
    # Pipeline IDs 1 to 9 are used for DRM CRTCs.  One should be assigned
    # to each display that will be used.
    pipeline1-display = 1
    # Pipeline IDs 10 and above are used for DRM planes.  A plane can only
    # be used on a display with an active CRTC.
    pipeline10-display = 1
  end wfd device
end khronos
begin winmgr
  begin globals
    input = keyboard mouse
    # Adjust the stack size of Screen's resmgr threads.  The default size
    # is insufficient for blitters/compositors using Mesa (e.g., gles2blt).
    blit-config = gles2blt
  end globals
  begin display 1
    video-mode = 1024 x 600 @ 75
    # Adjust the stack size of Screen's composition thread; required when the
    # display's framebuffer uses Mesa (e.g. "usage = gles2"), as noted above.
    cursor = on
    stack-size = 4096  # in units of 1024 bytes
  end display
  begin class framebuffer
    # Be sure to configure the "pipeline%d-display" options (above) so the
    # specified display and pipeline are bindable.  Normally a framebuffer
    # will use a CRTC pipeline.
    display = 1
    pipeline = 1
    format = rgba8888
    usage = gles2blt
  end class
  begin mtouch
    driver = devi
    options = height=600,width=1024
    display = 1
  end mtouch
end winmgr
Re: QNX 6.6 touch screen setup
Can you post the output from devi-hid in verbose mode after you touch the screen:
Devi-hid -vvvvvvv touch
Leave out the kid module as its already handled by screen.
Thanks for reply.
I've changed devi-hid command of rc.local to:
devi-hid -vvvvvvv touch
then sloginfo output after booting:
# sloginfo
Sep 04 00:53:51    2    19   1500 devb-ahci cam ver 100 sim 1.00A (Feb 22 2014 18:20:52)
Sep 04 00:53:51    2     5     0 libcam.so (Feb 22 2014 18:20:44) bver 6060109
Sep 04 00:53:51    2    19   1500 eide_identify_devices: AHCI (generic) vid 0x8086, did 0x1e03, class 0x10601, rev 0x4,
busno 0x0, dfunc 0xfa, base 0xf7d36000, irq 0xf, xlat 0x0
Sep 04 00:53:51    2    19   1500 eide_display_identify: mdl SAMSUNG MZMPC064HBDR-00000 sn S0VRNYAC200381 fw CXM1201Q
port 2, max udma 6, cur udma 5, max mdma 2, cur mdma 0, pio 4, mblk 16
Sep 04 00:53:51    2     5   100 cam-disk.so (Feb 22 2014 18:20:50)
Sep 04 00:53:51    5     3   1000 fs-qnx6: trim was requested, and is usable
Sep 04 00:53:51    5     6     0 random: Selecting timer as entropy source
Sep 04 00:53:51    5     6     0 random: All ready, registering path names
Sep 04 00:53:51    5     6     0 random: Daemonizing the process
Sep 04 00:53:51    2     9     0 Error: No such file or directory - cannot open calibration file for absolute filter
module(/etc/system/config/calib.localhost)
Sep 04 00:53:51    5    14     0 tcpip starting
Sep 04 00:53:51    3    14     0 Using pseudo random generator.  See "random" option
Sep 04 00:53:51    5    14     0 initializing IPsec... done
Sep 04 00:53:51    5    14     0 IPsec: Initialized Security Association Processing.
Sep 04 00:53:51    5    14     0 wm0
Sep 04 00:53:51    5    14     0 wm1
Sep 04 00:53:51    5    14     0 wm2
Sep 04 00:53:51    5    14     0 wm3
Sep 04 00:53:51    5    14     0 wm4
Sep 04 00:53:52    5    14     0 wm5
Sep 04 00:53:52    5     8   300 screen: starting up...
Sep 04 00:53:52    5     8   300 screen: connected to powman...
Sep 04 00:53:52    1     7     0 driver missing hw device index callback, ducking will not work properly between devices
Sep 04 00:53:52    3     8   915 [ihold:265]"warning"
Sep 04 00:53:52    5     8   300 screen: loading EGL display 1...
Sep 04 00:53:52    5     8   300 screen: loading blit module gles2blt...
Sep 04 00:53:53    3    12     0 devh-egalax.so - Failed to send check active (loopback) command to the controller: 5
Sep 04 00:53:53    5     8   300 screen: display_mode_set: selecting preferred mode 5 for display 1
Sep 04 00:53:53    5     8   300 screen: loading composition module gles2blt...
Sep 04 00:53:53    5     8   300 screen: win_cursor_init: No cursor specific in graphics.conf
Sep 04 00:53:53    5     8   300 screen: win_cursor_shape_init: using default cursor (9x16)
Sep 04 00:53:53    5     8   300 screen: loading mtouch module devi...
Sep 04 00:53:53    5     9   200 devi[INFO]:  Connected to TP on /dev/devi/touch0
Sep 04 00:53:53    5     9   100 libinputevents[INFO]: Attaching mtouch driver
Sep 04 00:53:53    5     9   100 libinputevents[INFO]: Changing mtouch coordinate mapping
Sep 04 00:53:53    5     9   100 libinputevents[INFO]: Opening mtouch device #0
Sep 04 00:53:53    5     8   300 screen: attached to mtouch0
Sep 04 00:53:53    5     8   300 screen: connected to HID...
About the error of calibration file missing,
if I put calibration file from qnx650 to /etc/system/config then the error message has removed but still not working.
If I run devi-hid in command line, output is different.
# devi-hid -vvvvvvv touch
Looking up touch in module table
Calibration filename: /etc/system/config/calib.localhost
Resetting module touch
Resetting module abs
Error: No such file or directory - cannot open calibration file for absolute filter module(/etc/system/config/calib.
localhost)
Did not find calib info for [639x479].  Attempting to use calculated transformation.
Calibration Matrix An: 0, Bn: 0, Cn: 0, Dn: 0, En: 0, Fn: 0, Divider: 0
If /etc/system/config/calib.localhost exist, just "Error:No such ..." message removed and no difference.
did you have any progress? I am having the same problem.
Regards
No, I'm still stuck on it.
In my case, touchscreen controller is not HID-compliant so I can't use "io-hid -dusb" instead of "io-hid -degalax".
I'm using ETP-4500UG-B touchscreen controller.
I've been asking to QNX support from two weeks ago but no luck yet.
I am also trying to use touch screen with QNX 6.6 on TI Jacinto 6 (DRA74x) EVM (Rev E1) with 7" display.
I have used the screen patch and apps & media and run the driver for touch as per the QNX SDP user guide that came along with the BSP.
When I run the calib-touch utility, I get the calibration display but my touch inputs don't get registered.
I am not able to calibrate.
I have added the resolution of LCD I am using (800x480) to /etc/system/config/scaling.conf i.e.
800x480:mode=direct
Here is the sloginfo output when I run screen:
Jan 01 00:00:15    5     8   300 screen: starting up...
Jan 01 00:00:15    5     8   300 screen: connected to powman...
Jan 01 00:00:15    5     8   200 wfd: 1 wfdCreateDevice - Tiler is not available. Video buffer will be allocated in normal memory
Jan 01 00:00:15    5     8   200 wfd: 1 configure_sys_clock - System clock is set to: 20000 KHz
Jan 01 00:00:15    5     8   200 wfd: 1 configure_dss_func_clock - DSS func clock is set to: 192000 KHz
Jan 01 00:00:15    2     8   300 screen: invalid display id:
	>>>   begin display 1
Jan 01 00:00:15    5     8   300 screen: loading EGL display 1...
Jan 01 00:00:15    2     8   100 SGX - Starting SGX release driver (version: 1.9@2291151)
Jan 01 00:00:15    2     8   100 SGX - Power management turn ON
Jan 01 00:00:15    2     8   100 SGX - TKT26818_OPTIMIZATION_SUBSET enabled
Jan 01 00:00:15    2     8   100 SGX - SKIP_ISR_PULSE_WHEN_GPU_OFF enabled
Jan 01 00:00:15    5     8   300 screen: loading blit module pvr2d...
Jan 01 00:00:15    5     8   300 screen: loading composition module pvr2d...
Jan 01 00:00:15    5     8   300 screen: loading mtouch module devi...
Jan 01 00:00:15    5     9   200 devi[INFO]:  Connected to TP on /dev/devi/touch0
Jan 01 00:00:15    5     9   100 libinputevents[INFO]: Attaching mtouch driver
Jan 01 00:00:15    5     9   100 libinputevents[INFO]: Opening mtouch device #0
Jan 01 00:00:15    5     8   300 screen: attached to mtouch0
So it doesn't look like there is any problem with the driver.
Can anyone suggest what could be going wrong?
Thanks in advance.
I am attaching the graphics.conf that I am using.
Abhishek
Attachment: Text graphics.conf 1.38 KB
I've changed touch screen controller to HID compliant device. After figuring out what's going on, QNX support guy said
that something is different between their egalax touch screen controller and mine. And if I want to go further, I have
to pay 10000$ at least for priority support(bronze). Even though it works with QNX 6.5.0.
Anyway, now I can touch and move the cursor on the screen but coordinates are not fit.
So I've tried to calibrate but result was same as you. The cursor moves, but calib-touch program doesn't accept or
recognize that.
I'm using a screen with 1024x600. But when I run 'devi-hid' from command line, some suspected output displayed.
# devi-hid -vvvvvvv mouse touch
I've set the resolution to 1024x600 through the same way as you and I don't know why that message displayed.
As your result is same with me, I wonder what's the output from devi-hid from command line with -vvvvvvv?
May be uses egalax driver in section (as the documentation):
 begin mtouch
    driver = egalax
    display = 1
  end mtouch
But then:
libs: load_object: attempt load of libmtouch-egalax.so
libs: dlopen: Library cannot be found
Where to get the library "libmtouch-egalax.so"?
I solved my problem:
I didn`t use egalax driver, but used usb driver:
# io-usb -dehci -dohci -duhci -dxhci
# io-hid -dusb
# hidview
HIDD v1.00, v1.00 DDK
Device Address       : 0
Product              : 0x0001 (USB TouchController)
Version              : r1.10
Usage                : Pointer
# devi-hid touch
# screen
# calib-touch -recalibrate
graphics.conf:
begin khronos
  begin egl display 1
  end egl display
  begin wfd device 1
#    pipeline2-display = 2
#    pipeline11-display = 2
  end wfd device
end khronos
begin winmgr
  begin globals
    stack-size = 2048  # in units of 1024 bytes
  end globals
  begin display 1
    video-mode = 1280 x 1024 @ 60
  end display
#  begin display 2
#    video-mode = 800 x 600 @ 60
#    stack-size = 2048  # in units of 1024 bytes
#  end display
  begin mtouch
        driver = devi
        options = height=1024,width=1280
        display = 1
  end mtouch
end winmgr
scaling.conf:
# Scaling based on calibration data
1280x1024:mode=calib,disp_x=[102:922:922:102],disp_y=[60:60:540:540],mtouch_x=[172:1108:1108:172],mtouch_y=[110:110:658:
658]
# Scaling based on physical dimensions
1280x1024:mode=dim,width_mm=154,height_mm=90,border_left_mm=5,border_right_mm=5,border_top_mm=5,border_bottom_mm=5
# Simple scaling to client resolution
1280x1024:mode=scale
# No scaling, report coordinates exactly as the driver hands them to the client
1280x1024:mode=direct
Good luck to everyone....
