Forum Topic - Creating a PNG output file.:
I have a rectangular array in memory of RGB values (i.e., it is IMG_FMT_RGBA8888 data) and would like to output a PNG
file from that data.  How would this be done?
RE: Creating a PNG output file.
Hi Ronald,
Try this it should work :) .... search for "Lavin" to see my comments inline....
   uint32_t *img_buf = NULL;
   uint32_t image_size = Max size of the RGB data buffer;
   int32_t           result = EOK;
   img_lib_t         ilib;
   img_codec_t       codec_buf;
   int               n_codecs;
   img_t             img;
   io_stream_t       *image_stream_fd;
   char              mime[64];
   uintptr_t         temp_encode_data = 0;
   /* allocate (image_size/sizeof int-(4bytes)) elements of type int */
   if (NULL == (img_buf = calloc((image_size / (sizeof(uint32_t))), sizeof(uint32_t)))) {
      _error("%s: Memory allocation for %d bytes failed", __FUNCTION__, image_size);
      return ENOMEM;
 /* Lavin : copy the image RGB values linearly to the above allocated img_buf, from your rectangular array in memory */
 /* Lavin : at this point I assume that you have already copied the image data to img_buf.*/
 /* Lavin : NOTE: you can very well use your rectangular array directly as image_buf as well :) */
      //Attaching to the image library
      memset(&img,0,sizeof(img_t));
      /* get the resolution details */
      img.w = 1440; // 1440 or 960 , use accordingly
      img.h = 540; // 540, use accordingly
      img.format =  IMG_FMT_RGBA8888;
      img.flags |= IMG_FORMAT | IMG_W | IMG_H | IMG_DIRECT;
      img.access.direct.data = img_buf;
      img.access.direct.stride = (img.w * 3 );
      if ((result = img_lib_attach(&ilib)) != IMG_ERR_OK) {
         fprintf(stderr, "img_lib_attach() failed: %d\n", result);
         return result;
      memset(mime, '\0', 64 );
      sprintf(mime, "image/%s", "png");
      if(EOK == (n_codecs =  img_codec_list_bymime( ilib,
                             mime,
                             &codec_buf,
                             10 )))
         _error("%s: img_codec_list() No Codecs found on target !", __FUNCTION__);
         return -1;
      //convert the image_fd to stream_fd required by image libs.
	/* Lavin : here file_fs should be your xxx.png file fd after open(...O_CREATE) */
      if(NULL == (image_stream_fd = io_open( IO_FD, IO_WRITE, file_fd )))
         _error("%s: io_open() failed: %d", __FUNCTION__);
         return -1;
      //set the codec
      //Prepare to encode a frame to a stream
      if (img_encode_begin(codec_buf, image_stream_fd, &temp_encode_data) != IMG_ERR_OK)
         _error("%s: img_encode_begin() failed", __FUNCTION__);
         return -1;
      if ( (result = img_encode_frame(codec_buf, image_stream_fd, NULL, &img, &temp_encode_data)) != IMG_ERR_OK)
         _error("%s: img_encode_frame() failed: %d", __FUNCTION__, result);
         return -1;
      (void)img_encode_finish(codec_buf, image_stream_fd,  &temp_encode_data);
      io_close( image_stream_fd );
      /* done with img lib */
      img_lib_detach(ilib);
	/* Lavin : Now your PNG fromat file is ready :) :) */
Lavin,
From: Ronald Burkey [mailto:community-noreply@qnx.com]
Sent: Friday, August 12, 2011 9:52 PM
To: advanced-graphics
Subject: Creating a PNG output file.
Advanced Graphics
http://community.qnx.com/sf/go/post88079
Just now I noticed that you have RGBA8888, in this case I think you should modify below lines highlighted below using '-
Also pl make sure you configure the img.w/h appropriately.
Cheers,
Lavin
Sent: Wednesday, August 17, 2011 5:43 PM
Subject: RE: Creating a PNG output file.
Hi Ronald,
   img_lib_t         ilib;
   int               n_codecs;
   img_t             img;
   char              mime[64];
      return ENOMEM;
-->      img.access.direct.stride = (img.w * 4 );
         return result;
                             mime,
                             &codec_buf,
                             10 )))
         return -1;
         return -1;
      //set the codec
         return -1;
         return -1;
Lavin,
Advanced Graphics
Re: Creating a PNG output file. [bcc]
I had just made that change about 10 seconds before your message
arrived. :-) I haven't gotten to the point yet where I can run the
code.  I'll let you know what happens.
I assume that if I want jpg or bmp, it's just a matter of changing the
mime type appropriately?
Thanks!
Ron
> Cheers,
> Lavin
> From: Pottekkat, Lavin
> Hi Ronald,
>     img_lib_t         ilib;
>     int               n_codecs;
>     img_t             img;
>     char              mime[64];
>        return ENOMEM;
>           return result;
>                               mime,
>                               &codec_buf,
>                               10 )))
>           return -1;
>           return -1;
>        //set the codec
>        if (img_encode_begin(codec_buf, image_stream_fd,&temp_encode_data) != IMG_ERR_OK)
>           return -1;
>        if ( (result = img_encode_frame(codec_buf, image_stream_fd, NULL,&img,&temp_encode_data)) != IMG_ERR_OK)
>           _error("%s: img_encode_frame() failed: %d",...
RE: Creating a PNG output file. [bcc]
Yes, you can change the mime type for different file formats.
Lavin
Sent: Wednesday, August 17, 2011 6:10 PM
Subject: Re: Creating a PNG output file. [bcc]
Thanks!
Ron
> Cheers,
> Lavin
> Hi Ronald,
>     img_lib_t         ilib;
>     int               n_codecs;
>     img_t             img;
>     char              mime[64];
>        return ENOMEM;
>           return result;
>                               mime,
>                               &codec_buf,
>                               10 )))
>           return -1;
>           return -1;
>        //set the codec
>           _error("%s:...
Thanks, Lavin.  It seems to work fine, after appropriate changes for my
environment.
> Regards,
> Lavin
> Thanks!
> Ron
One final (I hope) question:  If JPGs were being output rather than
PNGs, how can the quality/compression be set?
-- Ron
> From: Lavin Pottekkat [mailto:community-noreply@qnx.com]
> Sent: Wednesday, August 17, 2011 7:53 AM
> Subject: RE: Creating a PNG output file. [bcc]
> Regards,
> Lavin
> Thanks!
> Ron
> should modify below lines highlighted below using '-->'
> > Cheers,
> > Lavin
> > Hi Ronald,
comments
> inline....
> >     img_lib_t         ilib;
> >     int               n_codecs;
> >     img_t             img;
> >     char              mime[64];
int */
__FUNCTION__,
> image_size);
> >        return ENOMEM;
allocated
directly
> >           return result;
Though i have not tried changing the compression techniques, i have seen noticeable difference in the size of the images
 created with different formats.
Lavin
Sent: Wednesday, August 17, 2011 9:52 PM
-- Ron
> Regards,
> Lavin
> Thanks!
> Ron
> > Cheers,
> > Lavin
> > Hi Ronald,
comments
> inline....
> >     img_lib_t         ilib;
> >     int               n_codecs;
> >     img_t             img;
> >     char              mime[64];
int */
__FUNCTION__,
> image_size);
> >        return ENOMEM;
allocated
directly
> >        if ((result = img_lib_attach(&ilib)) != IMG_ERR_OK)...
Re: Creating a PNG output file. [bcc][auto-ip]
True.  I don't lack space, so that doesn't actually concern me.  But I
gather you don't know how it can be done, so the point is moot.
Ron
images created with different formats.
> Regards,
> Lavin
> From: Ronald Burkey [community-noreply@qnx.com]
> -- Ron
RE: Creating a PNG output file. [bcc][auto-ip]
No idea how you can change the compression /quality :(,
Check if img_load_resize_file() is of any use....
Lavin
Sent: Wednesday, August 17, 2011 10:38 PM
Subject: Re: Creating a PNG output file. [bcc][auto-ip]
Ron
> Regards,
> Lavin
> -- Ron
Advanced Graphics
http://community.qnx.com/sf/go/post88170
