Forum Topic - qnx graphics driver development issue: (2 Items)
Hi, All
I met some issues when developing graphics driver for qnx.
1. It looks like that all the modules in driver has to be built as binary. Can client driver module be separted with
server modules(loaded by io-display)?
2. What's the usage of gf_display_devctl, in ddk there is no description about this api.
In my implementation there is a core driver which manages the hw resource including mode and memory management, kick off
 command to hw by dma buffer, it is loaded by io-display.
Instead of standard protocol such as set mode, allocated surface, I need some customized protocols to talk to resource
management modules from 2d client driver .
2d client driver -> io_display  -> (resource management modules driver)
 I tried to use gf_display_devctl , and implement devctl of mode module.But it mets the deak lock.
gf_draw_begin() -->lock the hw_mutex
gf_draw_flush() ->gf_display_devctl() ->io_display()  it will also try to lock hw_mutex
gf_draw_end() -->unlock the hw_mutex
Is there ay path to bypass this lock?
Thanks!
Ivan
RE: qnx graphics driver development issue
1.	The devg driver gets buit as a shared library (dll).  It will
get loaded by both the server (io-display) and clients (applications)
Certain functions are handled by the server (modeswitch, layer
managenent, memory management) but others are loaded in by each client
(core/context rendering functions).
2.	gf_display_devctl() is used to send a driver specific call to a
driver.   This call relates to properties of the display (mode, layers
etc.)   For example if your controller had some kind of special layer
setting not handled by the existing API you could pass values to driver
this way.   This should not be called from within a gf_draw_begin() and
gf_draw_end()
There is also a gf_devctl() function that can send a driver specific
call relating to rendering.  For example if you needed to configure some
draw property or registers the existing API doesn't support you could do
this here.
gf_devctl() should be called between gf_draw_begin() and gf_draw_end()
This sounds to be the function you're looking for.
Regards
Mike
Sent: June 2, 2010 11:56 PM
To: advanced-graphics
Subject: qnx graphics driver development issue
Hi, All
binary. Can client driver module be separted with server modules(loaded
by io-display)?
about this api.
resource including mode and memory management, kick off command to hw by
some customized protocols to talk to resource management modules from 2d
client driver .
to lock hw_mutex
Thanks!
Ivan
Advanced Graphics
http://community.qnx.com/sf/go/post55973
