Re: RE: i.MX51 graphics issue
04/07/2010 2:42 AM
post51246
Hello Mike,
Thank you for you advice.
I had installed only devg-soft3d.so.
And I added devg-soft3d-fixed.so.
It start running now.
Also vsync is running.
Thank you for your help.
Best Regards,
- Inami
> Are you able to run any 2D applications such as vsync?
> Do you have the software 3D library on your target?
> (devg-soft3d-fixed.so)
> If you try the following it will tell you if you're missing a library:
> DL_DEBUG=1 egl-gears-lite
> Thanks
> Mike
> From: Kazunori Inami [mailto:community-noreply@qnx.com]
> Sent: April 6, 2010 4:03 AM
> To: advanced-graphics
> Subject: i.MX51 graphics issue
> Hello,
> I like to show somthing on the display connected with i.MX51 board
> through DVI.
> I downloaded BSP from Foundry27.
> I tried to use egl-gears-lite which was ARMLE version in IDE.
> But I got this error.
> # egl-gears-lite
> Couldn't find a compatible frame buffer configuration on layer 0
> Could you please let me know how to make it work ?
> Or the easiest way to show some graphics on the screen.
> Best Regards,
> - Inami
> Advanced Graphics
> http://community.qnx.com/sf/go/post51187
