Mounting qnx4 fs with errors
05/15/2012 10:34 AM
post93087
Dear all,
I'm new to QNX. I would like to recover files from a qnx4 filesystem on a harddrive. The hardrive has 6 partitions. I
used the BOOT-CD and the photon file manager. If I do a df, it sees :
/dev/hd0
/dev/hd0t77
/dev/hd0t77.1
/dev/hd0t77.2
/dev/hd0t77.3
/dev/hd0t77.4
/dev/hd0t77.5
If I try to mount /dev/hd0t77 or any of its declination, it says that the fs is corrupted.
To my knowledge, the disk is not damaged. Do you see any reason for this message or any solution for me?
Is there a way to fix the fs?
Many thanks,
david.
RE: Mounting qnx4 fs with errors
05/15/2012 10:40 AM
post93088
First thing to try is chkfsys, which is the QNX4 file system checker tool. If you don't want to make any changes to the
disk, the -f option will prevent the tool from modifying anything.
> From: David Billard [mailto:community-noreply@qnx.com]
> Sent: May-15-12 10:35 AM
> To: general-filesystems
> Subject: Mounting qnx4 fs with errors
> Dear all,
> harddrive. The hardrive has 6 partitions. I used the BOOT-CD and the photon
> /dev/hd0
> /dev/hd0t77
> /dev/hd0t77.1
> /dev/hd0t77.2
> /dev/hd0t77.3
> /dev/hd0t77.4
> /dev/hd0t77.5
> corrupted.
> Many thanks,
> david.
> http://community.qnx.com/sf/go/post93087
> To cancel your subscription to this discussion, please e-mail general-
> filesystems-unsubscribe@community.qnx.com
Re: Mounting qnx4 fs with errors
05/15/2012 10:35 AM
post93090
Hi David,
it says that my partition is not a QNX4 fs. A rapid view with fdisk says
"unknown loader". Is there any way to detect which fs is on the partitions (I'm
almost sure it's qnx4, but perhaps am i wrong).
many thanks,
David.
the disk, the -f option will prevent the tool from modifying anything.
>> -----Original Message-----
>> Dear all,
>> /dev/hd0
>> /dev/hd0t77
>> /dev/hd0t77.1
>> /dev/hd0t77.2
>> /dev/hd0t77.3
>> /dev/hd0t77.4
>> /dev/hd0t77.5
>> corrupted.
>> Many thanks,
>> david.
>> General
> http://community.qnx.com/sf/go/post93088
> To cancel your subscription to this discussion, please e-mail general-filesystems-unsubscribe@community.qnx.com
Prof. David Billard | David.Billard@hesge.ch
University of Applied Sciences in Geneva | tel: +41 22 388 1885
Bât. F, 7 route de Drize - CH-1227 Carouge | fax: +41 22 388 1701
05/15/2012 10:40 AM
post93091
What OS version are you running? Partition type 77 is normally reserved for partitions of type QNX4. Fdisk should say
"QNX4" , simply because the type is 77. You can also try chkqnx6fs, on the off chance that the disks are formatted
with the QNX6 file system.
David
> Sent: May-15-12 10:33 AM
> To: general-filesystems@community.qnx.com
> Subject: Re: Mounting qnx4 fs with errors
> Hi David,
> (I'm almost sure it's qnx4, but perhaps am i wrong).
> many thanks,
> David.
> you don't want to make any changes to the disk, the -f option will prevent
> >> Dear all,
> >> on a harddrive. The hardrive has 6 partitions. I used the BOOT-CD and
> >> /dev/hd0
> >> /dev/hd0t77
> >> /dev/hd0t77.1
> >> /dev/hd0t77.2
> >> /dev/hd0t77.3
> >> /dev/hd0t77.4
> >> /dev/hd0t77.5
> >> Many thanks,
> >> david.
> >> General
> >> general- filesystems-unsubscribe@community.qnx.com
> > General
> http://community.qnx.com/sf/go/post93090
05/15/2012 11:59 AM
post93103
I'm using the boot-cd "qnxsdp-6.4.1-x86-200905201802-nto.iso".
chkqnx6fs returns nothing. That is it does something but then the prompt appears
and nothing is displayed at the screen.
Does it means it is really qnx6? In that case, do I need a special driver for
qnx6 fs?
David.
say "QNX4" , simply because the type is 77. You can also try chkqnx6fs, on the off chance that the disks are formatted
> David
>> Hi David,
>> many thanks,
>> David.
>>>> Dear all,
>>>> /dev/hd0
>>>> /dev/hd0t77
>>>> /dev/hd0t77.1
>>>> /dev/hd0t77.2
>>>> /dev/hd0t77.3
>>>> /dev/hd0t77.4
>>>> /dev/hd0t77.5
>>>> Many thanks,
>>>> david.
>>>> General
>>> General
>> General
>> To cancel your subscription to this...
05/31/2012 10:44 AM
post93407
Hi David,
Sorry to bother you with my problem. How can I mount a qnx6 file system (I'm
using the boot CD)?
Many thanks,
David.
> David
>> Hi David,
>> many thanks,
>> David.
>>>> Dear all,
>>>> /dev/hd0
>>>> /dev/hd0t77
>>>> /dev/hd0t77.1
>>>> /dev/hd0t77.2
>>>> /dev/hd0t77.3
>>>> /dev/hd0t77.4
>>>> /dev/hd0t77.5
>>>> Many thanks,
>>>> david.
>>>> General
>>> General
>> General
05/31/2012 11:06 AM
post93414
Ok, I found the "mount -t qnx6". Now I have a mounting problem. I can mount the
partitions:
/dev/hd0t77.1
/dev/hd0t77.2
/dev/hd0t77.3
/dev/hd0t77.4
/dev/hd0t77.5
But not the /dev/hd0t77 (which is the biggest partition but the numbering scheme
suggests that this partition is subdivided in 1 to 5 sub partitions). Does it
means that there is an unpartitionned (and unformatted) space on the drive?
Many thanks,
David.
Le 31.05.2012 16:37, David Billard a écrit :
> Hi David,
> using the boot CD)?
> Many thanks,
> David.
>> David
>>> Hi David,
>>> many thanks,
>>> David.
>>>>> Dear all,
>>>>> /dev/hd0
>>>>> /dev/hd0t77
>>>>> /dev/hd0t77.1
>>>>> /dev/hd0t77.2
>>>>> /dev/hd0t77.3
>>>>> /dev/hd0t77.4
>>>>> /dev/hd0t77.5
>>>>> Many thanks,
>>>>> david.
>>>>> General
>>>> General
05/31/2012 11:37 AM
post93420
Ok, I finally found it out. I rebooted the whole system and was able to mount
everything. May be there was a lock put on a file somewhere.
David.
> partitions:
> /dev/hd0t77.1
> /dev/hd0t77.2
> /dev/hd0t77.3
> /dev/hd0t77.4
> /dev/hd0t77.5
> Many thanks,
> David.
>> Hi David,
>> using the boot CD)?
>> Many thanks,
>> David.
>>> David
>>>> Hi David,
>>>> many thanks,
>>>> David.
>>>>>> Dear all,
>>>>>> /dev/hd0
>>>>>> /dev/hd0t77
>>>>>> /dev/hd0t77.1
>>>>>> /dev/hd0t77.2
>>>>>> /dev/hd0t77.3
>>>>>> /dev/hd0t77.4
>>>>>> /dev/hd0t77.5
>>>>>> Many thanks,
05/13/2013 4:37 AM
post101321
> Thanks,
> David.
> the
> > partitions:
> > /dev/hd0t77.1
> > /dev/hd0t77.2
> > /dev/hd0t77.3
> > /dev/hd0t77.4
> > /dev/hd0t77.5
> scheme
> it
> > Many thanks,
> > David.
> >> Hi David,
> (I'm
> >> using the boot CD)?
> >> Many thanks,
> >> David.
> for partitions of type QNX4. Fdisk should say "QNX4" , simply because the
> formatted with the QNX6 file system.
> >>> David
> >>>> Hi David,
> partitions
> >>>> many thanks,
> >>>> David.
> tool. If
> prevent
> >>>>>> Dear all,
> >>>>>> /dev/hd0
> >>>>>> /dev/hd0t77
> >>>>>> /dev/hd0t77.1
> >>>>>> /dev/hd0t77.2
> >>>>>> /dev/hd0t77.3
> >>>>>> /dev/hd0t77.4
> >>>>>> /dev/hd0t77.5
05/13/2013 4:38 AM
post101322
hello
i have some problem. in harman&decker cic for bmw x1.
i can mount this partitions, but in fdisk i see only extendet part.
how i can recreate 5 77 partition in fdisk ? (qnx6.5)
