Forum Topic - shell * fails on my resmgr directory:
I have a resmgr at attached to /dev/bucase QNX 6.4.1 (x86)
it has the next structure
# ls /dev/bucase/*
/dev/bucase/file1
/dev/bucase/test:
f     ff
So when I use next sequence of calls after start of resmgr
# echo /dev/bucase/*
/dev/bucase/file1 /dev/bucase/test
# echo /dev/bucase/test/*
/dev/bucase/test/f
So second call to echo fails, cause I have two entries in test directory
But ls /dev/bucase/test always work properly
# ls /dev/bucase/test
f     ff
Attaching minimum code with bug
Problem doesn't occur when I comment string that frees reply buffer to MsgReply call.
int handle_readdir(resmgr_context_t *ctp, io_read_t *msg, iofunc_ocb_t* ocb, struct myentry* entry){
	char* reply = (char*)malloc(msg->i.nbytes);
        int rsize;
       //Cycle at directory entries
       rsize = (char*)de - reply;
	if (-1 == MsgReply(ctp->rcvid, rsize, realrep, rsize)){
		perror("!!!!!readdir MsgReply");
	free(reply); //A comment of this string helps to avoid the problem but I cant clarify it (reply must be copied at the
moment of its freeing, isnt it?)
	return _RESMGR_NOREPLY;
Attachment: Text resmgr_echo_bug.c 5.88 KB
