Forum Topic - Mount of qnx6 file system:
I installed QNX 6.5.0 on a CF with the QNX6 file system 179.
I'm only able to mount this CF as "read only" in a QNX 6.5.0 Virtual Machine on my PC.
Why is this? I would like to mount and copy some files to the image. I've done this in the past on QNX file system 79.
Is there any solution/trick to do this?
Mikael
Re: Mount of qnx6 file system
Try adding "qnx6 sync=optional" to the end of your devb-xxx line.  Apparently, your CF card responds truthfully that is
does not support the "flush to disk" command required for qnx6fs.
