Forum Topic - tmpfs: (5 Items)
tmpfs
I am currently looking for information on using tmpfs under QNX. I am using qdb and the documentation for it mentions
being able to use tmpfs as a RAM based temporary storage. I have also seen other mentions of people using tmpfs on these
 forums.
However, I can't seem to find any further reference to tmpfs in the documentation, or on my development system. Is it
something that I'd need to port from Linux? Or am I better using ETFS in RAM? I thought having a transaction based FS
would be overkill.
Cheers.
RE: tmpfs
Hi David,
I believe typically io-fs-media is used for the RAM disk:
e.g.
# io-fs-media -dtmp
Cheers,
Andy
From: David McMinn [mailto:community-noreply@qnx.com]
Sent: Monday, April 18, 2011 6:44 AM
To: general-filesystems
Subject: tmpfs
using qdb and the documentation for it mentions being able to use tmpfs
people using tmpfs on these forums.
documentation, or on my development system. Is it something that I'd
having a transaction based FS would be overkill.
Cheers.
General
http://community.qnx.com/sf/go/post85078
Re: RE: tmpfs
Hi Andy,
Thanks for your reply.
I should probably mention the setup I'm using:
Commercial QNX 6.5.0 Windows hosted for x86 target.
Standard Neutrino RTOS, nothing else (i.e. I don't have Aviage)
I can't seem to find io-fs-media on my system either, nor any docs about it, probably because I don't have Aviage.
However, io-fs-media is mentioned in the multimedia document overview (http://www.qnx.com/developers/docs/6.5.0/index.
jsp?topic=/com.qnx.doc.neutrino_sys_arch/mme.html), but the link to the docs for io-fs-media (http://www.qnx.com/
developers/docs/6.5.0/topic/com.qnx.doc.mme_en_mme_utils_ref/io-fs.html) seems to go nowhere:
Is there any other information about it, even just to confirm that it only comes with Aviage?
If that's the case am I back to using etfs?
Cheers.
> Hi David,
> e.g.
> # io-fs-media -dtmp
> Cheers,
> Andy
> Subject: tmpfs
> Cheers.
Re: tmpfs
David-
The requirement for qdb is for an underlying "posix" filesystem.  It won't work on a simple link to /dev/shmem - so you
are right looking for tmpfs.  Apparently, tmpfs satisfies the posix requirement, but more efficiently than a full-blown
ram filesystem.
Short of having tmpfs, you can create a qnx4 filesystem in ram - more overhead but should work fine!
Create 4M ramdisk - it  will show up as /dev/hd1t77 or something similar...
# devb-ram ram capacity=8192 &
Then format and mount...
# dinit -h /dev/hd1t77
# mount /dev/hd1t77 /ram
Denniis
Re: tmpfs
Hi Denniis,
Thanks for the tips. I'll give it a go.
Cheers.
> David-
> work on a simple link to /dev/shmem - so you are right looking for tmpfs.
>  full-blown ram filesystem.
> Denniis
