Re: ETFS: sporadic total data loss when writing big files?
11/03/2009 5:23 AM
post41203
I've dug a bit deeper...
We use 2K Nand (1 GB), with ETFS Partition 2 starting at page 473088 (i.e. etfs called with "-r 946176"). With 2K Nand,
each block is 64 pages. On ETFS, each page is 2K and equals one ETFS cluster.
We modified the ETFS Transaction Read function of the BSP to print debugging information (you will see those included
further below as "reference A" and "reference B"). Then the following steps were executed on the target (8313):
1. format NAND ("nand erase" from UBoot to have a clean system)
2. etfs-format NAND (etfsctl -d /dev/etfs2 -f)
3. reboot, ensure the FS is up and running
4. write a file of 10.981.563 Bytes (as reported by windows/cygwin) to /tmp (via Momentics/qconn), then do a "cp" to /fs
/etfs
5. after writing the file has succeeded, reboot. The readtrans debug printfs are reference 'A'. Make sure that the file
is properly contained in ETFS (by reading it back and verifying)
6. create four or five empty files in /fs/effs by using "touch"
7. reboot. The readtrans debug printfs are reference 'B'.
During reboot, etfs prints "Truncating fid 0x6 from 10907648 to 0 bytes". After reboot, all files (large file and the
small touched files) are gone, so the filesystem is empty! From the readtrans debugging printfs, it seems fid 0x6 is the
large file. The small touched files are not even reported as lost during reboot, they just seem to vanish.
Here are some details:
(i've sometimes added a comment "new block" for seeing better where the block boundaries are)
"Reference A" (Booting after the large file has been written... edited for brevity)
(Start of ETFS)
cl 473088 ETFS_TRANS_ERASED
cl 473152 ETFS_TRANS_ERASED
cl 473216 ETFS_TRANS_ERASED
cl 473280 ETFS_TRANS_ERASED
cl 473344 ETFS_TRANS_ERASED
cl 473408 OK (seq 0x1 fid 0x1 clusters 0x0 nclusters 0x1
cl 473409 OK (seq 0x1 fid 0x1 clusters 0x0 nclusters 0x1
cl 473410 OK (seq 0x1 fid 0x6 clusters 0x0 nclusters 0x10
cl 473426 OK (seq 0x1 fid 0x6 clusters 0x10 nclusters 0x10
cl 473442 OK (seq 0x1 fid 0x6 clusters 0x20 nclusters 0x10
cl 473458 OK (seq 0x1 fid 0x6 clusters 0x30 nclusters 0xe
(new block)
cl 473472 OK (seq 0x2 fid 0x6 clusters 0x3e nclusters 0x10
cl 473488 OK (seq 0x2 fid 0x6 clusters 0x4e nclusters 0x10
cl 473504 OK (seq 0x2 fid 0x6 clusters 0x5e nclusters 0x10
cl 473520 OK (seq 0x2 fid 0x6 clusters 0x6e nclusters 0x10
cl 476160 OK (seq 0x2c fid 0x6 clusters 0xabe nclusters 0x10
cl 476176 OK (seq 0x2c fid 0x6 clusters 0xace nclusters 0x10
cl 476192 OK (seq 0x2c fid 0x6 clusters 0xade nclusters 0x10
cl 476208 OK (seq 0x2c fid 0x6 clusters 0xaee nclusters 0x10
(new block)
cl 476224 OK (seq 0x2d fid 0x6 clusters 0xafe nclusters 0x10
cl 476240 ETFS_TRANS_ERASED
(new block)
cl 476288 ETFS_TRANS_ERASED
(new block)
cl 476352 ETFS_TRANS_ERASED
(new block)
cl 476416 OK (seq 0x30 fid 0x6 clusters 0xbbe nclusters 0x10
cl 476432 ETFS_TRANS_ERASED
(new block)
cl 476480 ETFS_TRANS_ERASED
(new block)
cl 476544 ETFS_TRANS_ERASED
(new block)
cl 476608 OK (seq 0x33 fid 0x6 clusters 0xc7e nclusters 0x10
cl 476624 ETFS_TRANS_ERASED
(new block)
cl 476672 ETFS_TRANS_ERASED
(new block)
cl 476736 ETFS_TRANS_ERASED
(new block)
cl 476800 ETFS_TRANS_ERASED
(new block)
cl 476864 ETFS_TRANS_ERASED
(new block)
cl 476928 ETFS_TRANS_ERASED
(new block)
cl 476992 ETFS_TRANS_ERASED
(new block)
cl 477056 OK (seq 0x3a fid 0x6 clusters 0xe3e nclusters 0x10
cl 477072 OK (seq 0x3a fid 0x6 clusters 0xe4e nclusters 0x10
cl 477088 OK (seq 0x3a fid 0x6 clusters 0xe5e nclusters 0x10
cl 477104 OK (seq 0x3a fid 0x6 clusters 0xe6e nclusters 0x10
cl 478656 OK (seq 0x53 fid 0x6 clusters 0x147e nclusters 0x10
cl 478672 OK (seq 0x53 fid 0x6 clusters 0x148e nclusters 0x10
cl 478688 OK (seq 0x53 fid 0x6 clusters 0x149e nclusters 0x10
cl 478704 OK (seq 0x53 fid 0x6 clusters 0x14ae nclusters 0x10
(new block)
cl 478720 OK (seq 0x54 fid 0x6 clusters 0x14be nclusters 0x10
cl 478736 OK (seq 0x54 fid...
11/03/2009 5:40 AM
post41204
a small addtion..
the dumps of the NAND data have been done after the FS has been started up during the "reference B" printfs. This may
mean that ETFS has modified the data during the startup (?) as part of its repair process (?). This may explain why the
dumped data is in contradiction to the info reported by ETFS during startup "B".
But of course this doesn't explain nor solve the bug itself...
