Forum Topic - phlogin problem:
phlogin problem
I had couple of instances when phlogin did not accepted the passwords, but in the same time I was able to login via
telnet using the same passwords.
Then I re-entered the passwords using passwd utility and phlogin started working.
Do you know what might be the problem?!?
Re: phlogin problem
phlogin or phlogin2?
What OS Version?
If it is phlogin2 -- Did you click on a user icon before entering the password? (This bug should be fixed in 6.4.0)
Re: phlogin problem
Hello Misha,
It is about phlogin2 and the QNX OS version is 6.3.2.
This happened to me couple of times on my Dev station.
I was thinking somebody is fooling around.
Now it happened on the target mashine.
How can we fix it?!?!
Thank you in forward!
Re: phlogin problem
and yes I use to click on the user Icon first
Re: phlogin problem
I think if you re-type the user name, and then the  password it should work.
Re: phlogin problem
The problem occurs occasionally and can not be easy reproduced.
Next time when it happens I will try what you suggested.
Is it possible to use phlogin2 executable from 6.4.1( you said the problem was fixed in 6.4.0 ) into 6.3.2?
Kosta
Re: phlogin problem
I don't know, but I am sure you can try to use 6.4.1 on 6.3.0.
You can also try to build phlogin2 on your 6.3.0 system -- that should work fine.
