Forum Topic - ftpd and logging using slogger...:
don't know if this really fits into this forum category but didn't find anything better...
I'm trying to run ftpd on our target. Problem is, it tries to log via syslog, and we're running slogger.
Of course we could run syslogd in parallel - but we'd really prefer all logs to be in one place: slogger's logfile. Also
 syslog is not really tailored towards running on an embedded target where the majority of directories is not writable.
Any suggestions? I thought syslog() messages go to /dev/slog anyway on QNX, but it seems this is not true for all
applications/deamons?
I've tried to make syslog log to the console (which should be logged by slogger?), using "*.* /dev/console" in /etc/
syslog.conf... I read somehwere this will be logged by slogger...  but instead, this is printed to the serial console,
not slogger..
Greetings,
 Marc
Re: ftpd and logging using slogger...
On Tue, Aug 25, 2009 at 09:06:23AM -0400, Marc Roessler wrote:
Also syslog is not really tailored towards running on an embedded target where the majority of directories is not
writable.
not slogger..
Try:
# ln -sP slog /dev/log
RE: ftpd and logging using slogger...
> From: Sean Boudreau [mailto:community-noreply@qnx.com]
> Sent: August 25, 2009 10:46 AM
> To: ostech-core_os
> Subject: Re: ftpd and logging using slogger...
> > Hi,
> all applications/deamons?
> /etc/syslog.conf... I read somehwere this will be logged by
> console, not slogger..
> Try:
> -seanb
I'm curious why /dev/console isn't working.  If you do "echo test >
/dev/console", do you get output in sloginfo?  If  yes, then it's
something in syslogd, if not, something's wrong with the slogger setup.
Also, if you do "ls -li /dev/console /dev/slog", do they both have the
same inode?  If not, then something else may have registered
/dev/console.
David
> http://community.qnx.com/sf/go/post36624
Re: RE: ftpd and logging using slogger...
David, echoing to /dev/console prints to slogger, so this seems to work.
So the problem is likely with syslogd... will take a deeper dig into this.
What I don't get yet is: how is /dev/console actually used within QNX?
Anything started in the bsh startup skript prints to the serial console,
and starting with an appended "2>&1 > /dev/console" doesn't seem to work in the bsh boot skript (probably as it's not a "
real" shell).
Greetings,
 Marc
RE: RE: ftpd and logging using slogger...
> From: Marc Roessler [mailto:community-noreply@qnx.com]
> Sent: August 25, 2009 11:19 AM
> To: ostech-core_os
> Subject: Re: RE: ftpd and logging using slogger...
> seems to work.
> dig into this.
> serial console, and starting with an appended "2>&1 >
> (probably as it's not a "real" shell).
/dev/console is owned by slogger.  It's a plain-text input to slogger
(as opposed to /dev/slog, which looks for a header).  Any text sent to
/dev/console is simply added to the slog buffer.
> Greetings,
>  Marc
> http://community.qnx.com/sf/go/post36635
Thanks Sean... works - almost:
Aug 25 17:06:27    6 354080   1047 7:06:27 ftpd[12302-1]: using conservative LOG
IN_NAME_MAX valuedd<Aug J”7:06:27 ftpd[16397-1]: failed to write a pid file: No
such file or directory
Seems the log entries written by ftpd arrive at slogger somewhat garbled... it seems it sometimes tries to write
multiple syslog entries within one slogger entry... the special characters printed seem to cause the serial terminal
settings to be garbled when sloginfo is called within the terminal window.
Any ideas?
Greetings,
 Marc
> Sent: August 25, 2009 11:10 AM
> To: ostech-core_os
> IN_NAME_MAX valuedd<Aug J"7:06:27 ftpd[16397-1]: failed to
> write a pid file: No such file or directory ....
> terminal window.
> Any ideas?
/dev/slog makes assumptions about the format of the arriving data.
/dev/console assumes it's just receiving plain-text.  Try changing the
symlink to point to /dev/console instead of /dev/slog.
> Greetings,
>  Marc
> http://community.qnx.com/sf/go/post36633
Okay...
It works..
Solution:
- /dev/console was a pointer to /dev/ser1 in the BSP... which later was shadowed by slogger's /dev/console but seemed to
 cause problems nevertheless. Changed it, works better now.
- syslog.conf was faulty, used a space instead of a tab as separator... the strange error message was somewhat
misguiding me
Can this (i.e. the whole slogger vs. syslogd issue) be found in the docu somewhere? Would be nice if this was added, as
it's a rather standard problem i suppose...
Thanks & Greetings,
 Marc
