Forum Topic - MsgSendPulse to wake up an Interrupt Handler:
I've written two device drivers which have currently interrupt service routines which return an event upon determining
that an interrupt of interest has occured.
I've used InterruptAttach to define my interrupt service routine and have associated a pulse with an event handler, to
allow the calling of the event handler when the interrupt service routine returns an event, i.e.
const struct sigevent *mailboxISR(void *pArea, int id)
    mailboxDev_t   *mbxDev = pArea;
    if(SomeInterrupt)
        return &mbxDev->event;
    else
        return NULL;
int mailboxEventHandler(message_context_t *pMsgCtp, int code, unsigned flags, void *pHandle)
    /* Do the work for the interrupt */
const struct sigevent *frameISR(void *pArea, int id)
    frameDev_t   *frameDev = pArea;
    if(SomeInterrupt)
        return &frameDev->event;
    else
        return NULL;
int frameEventHandler(message_context_t *pMsgCtp, int code, unsigned flags, void *pHandle)
Both drivers have their own ISR and EventHandlers, but now I have to write a single ISR for both drivers, as there is
only one interrupt source for both drivers.
For this I have written a new driver which simply contains the ISR and an EventHandler.
My idea was that the new EventHandler would wake up the frameEventHandler or mailboxEventHandler upon detecting an
interrupt for those two devices.
But my question is, how can I send an pulse to wake-up the frameEventHandler or mailboxEventHandler from my new
interrupt driver EventHandler?
I thought I may be able to use MsgSendPulse with the appropriate coid and code for frameEventHandler/mailboxEventHandler
, but I can't get this to work.
I'm trying to minimise the amount of changes I need to do to my two existing drivers.
Any help would be greatly appriciated.
Cheers, Mark.
RE: MsgSendPulse to wake up an Interrupt Handler
> From: Mark Pearson [mailto:community-noreply@qnx.com]
> Sent: Monday, August 10, 2009 9:44 AM
> To: ostech-core_os
> Subject: MsgSendPulse to wake up an Interrupt Handler
> routines which return an event upon determining that an interrupt of
> have associated a pulse with an event handler, to allow the calling of
> i.e.
>     if(SomeInterrupt)
>     else
>         return NULL;
>     if(SomeInterrupt)
>     else
>         return NULL;
> write a single ISR for both drivers, as there is only one interrupt
I assume you mean each driver handle two different hardware that shares the same interrupt?  That's not an issue as long
 as each ISR check if the interrupt comes from the corresponding hardware.
If that is not the case.  You can use the _NTO_INTR_FLAGS_END to control the order into which the ISR is called.  Hence
making sure which ISR gets called first if that is important to your design.
> an EventHandler.
> frameEventHandler or mailboxEventHandler upon detecting an interrupt
> frameEventHandler or mailboxEventHandler from my new interrupt driver
> EventHandler?
> and code for frameEventHandler/mailboxEventHandler, but I can't get
> this to work.
> existing drivers.
> Cheers, Mark.
> http://community.qnx.com/sf/go/post35552
Re: RE: MsgSendPulse to wake up an Interrupt Handler
> same interrupt?  That's not an issue as long as each ISR check if the
> order into which the ISR is called.  Hence making sure which ISR gets called
Thanks for the quick reply.
Yes, the drivers handle two different hardware devices sharing a single interrupt.
So I can still use InterruptAttach and both ISRs will be called sequentially, with _NTO_INTR_FLAGS_END controlling the
order of the ISR calls? That would be perfect :-)
Many thanks, Mark.
RE: RE: MsgSendPulse to wake up an Interrupt Handler
> Sent: Monday, August 10, 2009 9:59 AM
> To: ostech-core_os
> Subject: Re: RE: MsgSendPulse to wake up an Interrupt Handler
> shares the
> control the
> called
> interrupt.
> sequentially, with _NTO_INTR_FLAGS_END controlling the order of the ISR
> calls?
Yes.  Check the documentation on InterruptAttach, it's all explained there.
> Many thanks, Mark.
> http://community.qnx.com/sf/go/post35562
Re: RE: RE: MsgSendPulse to wake up an Interrupt Handler
I think another way to do this is to write a cascaded interrupt callout to return 2 new vectors, and you driver will
attach to each vectors. This should have less overhead.
