Re: ifs (boot) file changes from 6.3.2 to 6.4.1
08/05/2009 3:49 AM
post35224
The problem solved.
There is a difference in "startup-bios" length in boot files between 6.3.2 and 6.4.1, so also "Image-header" part of ifs
file was on further addresses and it was causing overrun (0xffff) happening in our code.
Now taking into account this possibility it's working fine.
PKY
> Hello,
> We have custom way to boot a x86 board from a FAT formated CF, with a .boot
> file created with mkifs.
> This was created in 6.3 days.
> Now we want to switch to 6.4, so we have recompiled all our staff (also
> created .boot file on 6.4.1 system). Boot file is "working" on "normal" (not
> powerfail safe) partition.
> But our custom boot doesn't work.
> The same boot script compiled with QNX6.3.2 mkifs works fine.
> Were there any changes in a way system handles .boot file during boot? I
> haven't found anything in docs.
> Thanks, PKY
09/17/2015 2:27 PM
post114467
Have you refreshed the bootstrap on the qnx4fs? While your environment varialbles are set for 6.5, use "dinit -b /dev/
hd0t77" (or similar) to assure that the 6.5 version of ipl-diskpc2 is resident on disk. The 6.5 bootstrap will work
with the 6.5 startup-bios.
