Forum Topic - InterruptDetach and EPERM: (3 Items)
I have a test program that takes the interrupt id returned from another process' InterruptAttach and tries
InterruptDetach with it.
EPERM is returned by InterruptDetach.
In the docs,
"EPERM The process doesn't have superuser capabilities. "
Can I use an InterruptDetach from a different process? It is allowed?
If it is not allowed, should the docs note this other reason for an EPERM?
From errno.h,
#define EPERM            1  /* Not owner                                */
ThreadCtl(_NTO_TCTL_IO, 0) returns ok and I can successfully InterruptMask and InterruptUnmask with this same id in my
test program.
 _NTO_INTR_FLAGS_TRK_MSK | _NTO_INTR_FLAGS_END | _NTO_INTR_FLAGS_PROCESS are passed to InterruptAttach by the first
process.
thanks,
asherk
RE: InterruptDetach and EPERM
> From: Andrew Sherk [mailto:community-noreply@qnx.com]
> Sent: July 23, 2009 4:31 PM
> To: ostech-core_os
> Subject: InterruptDetach and EPERM
> In the docs,
There's a check in the detach code that makes sure the thread calling
InterruptDetach() belongs to the same process as the thread that called
InterruptAttach().  If that check fails, it returns EPERM.
> for an EPERM?
Probably.  Maybe something like this?
EPERM
	The process doesn't have superuser privelages or is not the
process that attached the interrupt identified by _id_.
> thanks,
> asherk
> http://community.qnx.com/sf/go/post34464
Thanks, Dave, for your feedback.
PR 70642 has been opened.
> > another process' InterruptAttach and tries InterruptDetach with it.
> > In the docs,
> is allowed?
> that called InterruptAttach().  If that check fails, it returns EPERM.
> > EPERM?
> EPERM
> the process that attached the interrupt identified by _id_.
