Forum Topic - Endianness conversion .. done automatically?:
Hi guys,
when using QNet to communicate between CPUs of differing endianness,
which endianness conversions are done automatically and which must I do myself?
As an example:
I want to send a proprietary message to the server. I build that message:
	reg_msg.io_msg_hdr.type = _IO_MSG;
	reg_msg.io_msg_hdr.combine_len = ...;
	reg_msg.io_msg_hdr.mgrid = _IOMGR_IO_...;
	reg_msg.io_msg_hdr.subtype = ...;
Those values are all uint16, so they need conversion.
This means that the Framework will convert these values, otherwise I couldn't check for the type on the destination CPU
- correct? What about mgrid and subtype, are those converted as well?
What about registering and sending Pulses...?
I initialize the pulse using SIGEV_PULSE_INIT() and send it to the Server using MsgSend() with a special message type
(proprietary). The pulse code will be the same on both CPUs, as it is 8 bits, so no problems with the endianness here.
What about the pulse value? Will it be swapped by the MsgDeliverEvent()? Usually it doesn't matter because the value has
 been set by the client before sending the event to the server. But in  our case we need to modify the value in the
server. Will it be automatically endianness swapped when sending the pulse to the client?
Thanks & Greetings,
 Marc
Re: Endianness conversion .. done automatically?
> Hi guys,
See "lib/c/resmgr/resmgr_endian.c" for what is handled automatically.  Generally you're on our own for content following
 DEVCTL and IOMSG headers (since there is no generic/defined format).
> As an example:
> check for the type on the destination CPU - correct? What about mgrid and
The internal framework converts all the header fields (type, len, mgrid and subtype).  It is your responsibility to
convert the rest based on the private content format (presumably identified by the mgrid/subtype pairing).
> using MsgSend() with a special message type (proprietary). The pulse code will
>  here.
My understanding is that the network/transport layer (npm-qnet) handles the endianisation of such kernel data structures
 in direct kercalls, but xtang would have to confirm.
See this snippet from the 6.4.1 Release Notes
<snipp>
Qnet doesn't fully support communication between a big-endian machine and a little-endian machine. However, it does work
 between machines of different processor types (e.g. ARMLE, x86) that are of the same endian-ness. If you require cross-
endian networking with Qnet, please contact your QNX sales representative.
</snipp>
/hp
There are more details about cross-endian Qnet in the Advanced Qnet Topics appendix in the Neutrino Programmer's Guide.
See http://www.qnx.com/developers/docs/6.4.1/neutrino/prog/adv_qnet_topics.html#WHATWRWHATNT (you'll likely have to
reunite the pieces of the URL).
