05/19/2009 4:22 PM
post29712
A customer is reporting that their application is attempting to use in excess of 3.5 GB of memory, and they are
encountering the "out of memory" error condition. They are also using pre 6.3.0 SP2, possibly before the 36-bit
addressing capability was added to x86 and PPC systems (customer system is x86).
- With 36-bit addressing support, can the application exceed 3.5 GB of memory used?
- How does one enable 36-bit addressing support? Is there a patch that needs to be installed, or some parameter on the
procnto line in the IFS build file?
Their applications is a database server. The high amount of memory usage is not because there is a memory leak, it is
due to the huge amount of logging that is being done.
Thanks in advance
