Re: TimerTimeout and QNET
05/12/2009 2:54 PM
post29300
The qnet gurus here may have a better idea, but it sounds like you want to reduce your qnet timeouts. Looking
at the usemsg for lsm-qnet.so the tx_retries option appears to be the one you are hitting.
Andrew?
Colin
Kostadin Vardin wrote:
> Hi Colin,
> Please find attached the sloginfo, where you will see what QNET is reporting.
> At the first line you see tx_xmit_init_conn_pkt(): to nd17 on L4 1.
> This is exactly the moment when I start my test case, get connection with the server on another node( looks like 17 )
and start heart beating.
> The second line and after is when I pull out the LAN cable.
> Immediately qnet starts reporting l4_tx_timeout() and as you see this happens every 400ms, until the line where it
reports
> - l4_tx_service(): exceeded 25 retries during....
> and then we see some QOS messages. At this time my client gets unblocked.
> My question is :
> How I can get notified by qnet when it detects timeouts and use this one as unblocking event.
> This is very critical, as we deal with surgery and I need to get unblocked in such a case. 400ms is OK as time out.
> Probably I can somehow setup number of retries to 1, and then I will get notified earlier.
> Please for your help,
> Kosta
> http://community.qnx.com/sf/go/post29299
cburgess@qnx.com
RE: TimerTimeout and QNET
05/12/2009 3:03 PM
post29301
Yeah, pulling cable is the worst case scenario.
2 numbers decided how long it takes QNET to declare a network down
happened.
1) periodic_ticks (by default this is 5, so we have a 200ms tick)
2) tx_retries (how many retries QNET will do before it give up, default
is 25)
So by default, if you have data try to sent across network (if you
don't have data transmitting, that's a different story), it takes about
5 seconds to declare the other node is down, and every connection to
that node will be cleaned up.
To meet you 400ms, you may try to reduce the tx_retries to something
like 1, or you can try to set periodic_ticks to 10 (100ms tick), and
adjust the tx_retries.
-xtang
> From: Kostadin Vardin [mailto:community-noreply@qnx.com]
> Sent: Tuesday, May 12, 2009 2:52 PM
> To: ostech-core_os
> Subject: Re: TimerTimeout and QNET
> Hi Colin,
> QNET is reporting.
> see this happens every 400ms, until the line where it reports
> gets unblocked.
> My question is :
> Kosta
