hidd_report_detach vs. hidd_report_attach
04/03/2009 12:06 PM
post25993
On my QXN 6.3.0 SP3 I use hidd_report_attach to attach to input and output reports of a device like this.
int iInputAttachResult = (iInputReportResult == EOK) ? hidd_report_attach(phcHIDConnection, pdiHIDDevice,
priInputReportInstance, 0, sizeof(CDeviceInstance *), &phrInputReport) : EOK;
if (iInputAttachResult != EOK)
SetErrorCode(iInputAttachResult);
break;
int iOutputAttachResult = (iOutputReportResult == EOK) ? hidd_report_attach(phcHIDConnection, pdiHIDDevice,
priOutputReportInstance, HIDD_REPORT_FILTER, 0, &phrOutputReport) : EOK;
if (iOutputAttachResult != EOK)
SetErrorCode(iOutputAttachResult);
break;
Both attaches succeed. Then I get report length and determine it does not match one I expect. So I detect to detach
reports and give up using device.
I do
if (phrOutputReport)
int iDetachResult = hidd_report_detach(phrOutputReport);
verify(iDetachResult == EOK);
if (phrInputReport)
int iDetachResult = hidd_report_detach(phrInputReport);
Here first report detach succeeds and the second faults on SIGSEGV inside of libhiddi.so. And it does it exactly the
same way regardless whichever report is detached first: input or output. So it looks like, a single call to the function
detaches boths reports and then the second call crashes. Could someone check what could that be? In preliminary
inputddk_iohid.pdf I have there are no special remarks for hidd_report_detach().
(gdb) fr
#0 AttachHIDReportsWithReportInstances (phcHIDConnection=0x8066588, pdiHIDDevice=0x805f0b8, priInputReportInstance=
0x805f108,
priOutputReportInstance=0x805f130, iInputReportResult=0, iOutputReportResult=0, pdiDeviceInstance=0x8065748) at xxxx
.c:7612
7612 if (phrOutputReport)
(gdb) n
7614 int iDetachResult = hidd_report_detach(phrOutputReport);
(gdb)
7615 verify(iDetachResult == EOK);
(gdb)
7618 if (phrInputReport)
(gdb)
7620 int iDetachResult = hidd_report_detach(phrInputReport);
(gdb)
Program received signal SIGSEGV, Segmentation fault.
0xb8201e04 in ?? ()
(gdb) bt
#0 0xb8201e04 in ?? ()
#1 0xb8206aa8 in ?? ()
#2 0x07fc6da0 in ?? ()
#3 0x00000000 in ?? ()
(gdb)
