Forum Topic - /etc/motd issues ..:
/etc/motd issues ..
we've noticed that the /etc/motd is only displayed sproadically when logging in via telnet. I've tested this on a full
QNX 6.4.0 2008/09/02 install in a VM, and on our mpc8313 target.
After creating the /etc/motd (world readable) and logging in via telnet, the message is sometimes displayed, but in most
 cases it is not.
As a side note, also /etc/issue.net is not displayed when logging in via telnet (tested on x86 in VM).
Any ideas?
Greetings,
 Marc
Re: /etc/motd issues ..
On Mon, Mar 23, 2009 at 09:43:37AM -0400, Marc Roessler wrote:
most cases it is not.
/etc/motd appears to be handled by this section of /etc/profile.  sshd
appears to always spit it out.
if test -f ~/.hushlogin -o "$TTY" = "not a tty"; then
 	echo -n >~/.lastlogin
else
 	echo "${DATE=$(date +%c)} on ${TTY}"
 	test /etc/motd -nt ~/.lastlogin && cat /etc/motd
 	test -s ~/.lastlogin && echo $(<~/.lastlogin)
 	echo "Last login: ${DATE} on ${TTY}" >~/.lastlogin
 	unset DATE
fi
I can't find any reference to /etc/issue.net.
Thanks Sean, found the issue with the motd... removed the lastlogin check, works now. I was a bit confused since this
doesn't seem to be standard Unix behavior to output motd only _once_ for each user.
Regarding the issue with /etc/issue (pun intended), I'd expect this to be printed before logging in. It is usually done
by either the getty or telnetd or sshd...
So i suppose this means that qnx telnetd doesn't support it...
Greetings,
 Marc
Yes, it does seem a bit strange.  I'll make a PR.
done by either the getty or telnetd or sshd...
Not telnetd currently.  It looks like you may be able to do something
similar with the 'Banner' option to /etc/ssh/sshd_config
> Greetings,
>  Marc
> http://community.qnx.com/sf/go/post25025
