Forum Topic - "Attempt to free a block not allocated" message:
Running perl 5.10 on the Neutrino 6.4.0 SDP we keep seeing the message:
 Attempt to free a block not allocated: 0x81b7b88
spewing out to the console (x86 VMWare) ... lots of different addresses.
I've tracked it down to code from the runtime loader/linker:
  http://community.qnx.com/integration/viewcvs/viewcvs.cgi/trunk/lib/c/ldd/xsupport.ci?root=coreos_pub&rev=200965&system
=exsy1001&view=markup
Looking at where the error is coming from, it can't be good =;-)  To reproduce
the problem you can grab a copy of Perl from the 'opt/crank' archive we maintain:
 http://www.cranksoftware.com/downloads/
Running the standard tests should show the message.
 Thomas
Re: "Attempt to free a block not allocated" message
Thanks for the report Thomas, we'll take a look.
Colin
>   http://community.qnx.com/integration/viewcvs/viewcvs.cgi/trunk/lib/c/ldd/xsupport.ci?root=coreos_pub&rev=200965&system=exsy1001&view=markup
> Thanks,
>  Thomas
> http://community.qnx.com/sf/go/post20051
cburgess@qnx.com
RE: "Attempt to free a block not allocated" message
Just so we don't duplicate efforts, Thomas has agreed to provide a
smaller or self contained test case to show the issue.  Once we have
that I can take a peek at what is going on.
 Cheers,
    Adam
   QNX Software Systems
   [ amallory@qnx.com ]
   With a PC, I always felt limited by the software available.
   On Unix, I am limited only by my knowledge.
       --Peter J. Schoenster
> From: Colin Burgess [mailto:community-noreply@qnx.com]
> Sent: Wednesday, January 14, 2009 2:17 PM
> To: ostech-core_os
> Subject: Re: "Attempt to free a block not allocated" message
> Colin
message:
addresses.
/x
> reproduce
we
> maintain:
> > Thanks,
> >  Thomas
> > OSTech
> cburgess@qnx.com
> http://community.qnx.com/sf/go/post20072
BTW Adam... the same message is showing here....
http://pkgserver.ott.qnx.com/6.4.1/builds/200901142130/logs/top.html
cburgess@qnx.com
Good to know, thanks.
 Cheers,
    Adam
> Sent: Friday, January 16, 2009 10:13 AM
> To: ostech-core_os
> cburgess@qnx.com
> http://community.qnx.com/sf/go/post20209
The stick-it note is still present.  I have something close to small,
but you may have to install
the /opt/crank bits to get it to run.
Hang on just a little bit more ...
 Thomas
Apparently there are reports that building svn also reproduces the issue
during our build cycle.  That said, if you have something small, that
would be great.
 Cheers,
    Adam
> From: Thomas Fletcher [mailto:community-noreply@qnx.com]
> Sent: Tuesday, February 17, 2009 8:07 PM
> To: ostech-core_os
>  Thomas
> http://community.qnx.com/sf/go/post22409
Re: RE: "Attempt to free a block not allocated" message
Adam Mallory wrote:
>  Just to follow up, I've posted the fix here:
http://community.qnx.com/sf/discussion/do/listPosts/projects.core_os/discussion.osrev.topc7124
A beer for you can be located in the Crank fridge.  Feel free to
exercise this offer
at your leisure.
Thanks Adam!
Thomas ... now on the lookout for ported apps with spurious -lmalloc lines!
> exercise this offer
> at your leisure.
> Thanks Adam!
> lines!
Sweet, make sure the label is put on it so that everyone knows it's my
beer!
Cheers,
    Adam
Beer allocators are notoriously unreliable, and unfair.  I wouldn't get my hopes up... :-)
>> exercise this offer
>> at your leisure.
>> Thanks Adam!
>> lines!
> beer!
> Cheers,
>     Adam
> http://community.qnx.com/sf/go/post26442
cburgess@qnx.com
You mean I can't get slabs of beer? Darn.  At least there is some
garbage/empty collection....
Cheers,
    Adam
It probably has some serious leaks, too... :-P
> Cheers,
>     Adam
> http://community.qnx.com/sf/go/post26445
cburgess@qnx.com
Hi, I also get this error message on QNX 6.6 during a dlclose()
"Attempt to free a block not allocated: 0x80b7b00"
The link for the fix seems to be broken :(.
I sent some diffs to the perl peeps WRT this.
