Forum Topic - Initial Baudrate for Console: (6 Items)
See subject..
We are trying to bootstrap a system (mpc8313) using the BDI2000 debugger.
I'm loading the QNX image to address 0x200000, then jumping there with "go 0x200000" (while this isn't how it should be
done officially, it works fine when doing this from UBoot).
Now the problem is, besides some little burps of garbage on the serial console not much happens. I suppose the Baudrate
is set wrong.
What Baud Rate does QNX use when there is no ROM monitor or Bootloader
(such as UBoot) to set it?
I tried modifying the const struct debug_device debug_devices[] in the
startup code to read "0xe0004500^0.115200.333333333.16" for the first serial port, but it didn't really change a thing..
Any help is appreciated.
Thanks & Merry Christmas,
 Marc
Re: Initial Baudrate for Console
I don't know the answer but we have some docs about JTAG debugging:
http://www.qnx.com/developers/docs/6.4.0/ide_en/user_guide/debug.html#JTAGAbtron
and
http://www.qnx.com/developers/articles/article_921_1.html
Marc Roessler wrote:
> See subject..
be done officially, it works fine when doing this from UBoot).
Baudrate is set wrong.
>  Marc
> http://community.qnx.com/sf/go/post19128
I found that by modifying the mentioned struct I get _one_ message,
"Starting on-board ethernet with TCP/IP stack.."
but that's it... it seems this speed setting only affects parts of the system,
the Neutrino Kernel itself seems to log to someplace else regardless of what
baud rate I set...?
Greetings,
 Marc
some new details...
kernel messages are not displayed during boot,
after starting devc-ser8250 starting display_msg seems to work from the startup bsh script,
starting drivers (tcpip, nand, pci, spi, ...) seems to freeze the system..
when i start the system with all drivers commented out (except devc-ser8250) I get a Shell prompt ("#"), but giving any
commands or pressing enter seems to lock up the system again/no reaction any more..
any ideas? maybe some memory areas not mapped right?
bump...
still stuck at that problem..
Can't really start and driver as it seems when booting.. any idea?
Serial Driver seems to work, but nothing else.. ETFS, PCI, NET..they all just get stuck..
The debug callouts and devc-ser8250 are more or less independent, other than both drive the same hardware. You should be
 able to get the debug callouts working with the settings used for the serial driver. Most startups permit the debug
callouts to be setup using the -D and -K options, which should shorten your turn around time.
As for the other problems - offen I think it comes down to having the memory and/or interrupts incorrectly configured.
The initial state of the system is also something to examine. If the system is booting from u-boot you might want to try
 comparing the initial system state with and without uboot.
> bump...
> get stuck..
