Forum Topic - open channels: what's a reasonable maximum?:
I'm dealing with a customer problem.  They are seeing a ConnectAttach call to devb-umass never returning.  Investigating
 has shown that the routine is getting stuck in the search for a channel to re-use.  It loops over the channels vector
but gets preempted before it has a chance to complete.
There are 10348 entries in the channels vector.  We get 2 or three interrupts every millisecond on this board.  The loop
 over the channels vector gets no further than about 5000 iterations (usually much less) before it gets preempted.
My question: is it a bug for devb-umass to have that many channels open?  Or is it a bug that the kernel doesn't handle
it correctly?
I think we need to change ker_connect_attach to handle an arbitrary number of channels without preemption troubles...
Agree?  Disagree?
There may also be a bug in devb-umass, though.  It seems suspicious that it has that many entries in its chancons vector
btw, the problem was spotted in 6.3.0...
RE: open channels: what's a reasonable maximum?
> From: Douglas Bailey [mailto:community-noreply@qnx.com]
> Sent: November 6, 2008 11:34 AM
> To: ostech-core_os
> Subject: open channels: what's a reasonable maximum?
> Investigating has shown that the routine is getting stuck in
> channels vector but gets preempted before it has a chance to complete.
> it correctly?
> Agree?  Disagree?
Either change it, or have a hard limit, and promise that we always work
up to that limit.
> suspicious that it has that many entries in its chancons vector...
Also agree.  I don't' see why it needs more than a handful of open
channels.  We're talking channels, and not coids, right?
> http://community.qnx.com/sf/go/post16111
Re: open channels: what's a reasonable maximum?
Not being entirely familiar with the way devb-umass works, I can't say whether
or not there's a bug in devb-umass ... but it sure does seem odd that the
kernel wouldn't handle an arbitrary number of channels (well ... *large*
arbitrary number).
That being said, I would classify it as a kernel bug, although, the kernel bug
may not be the only one in play here.
I agree on changing ker_connect_attach to deal with preemption ... a good
approach in this case may be to save the state of the iteration ... so, even
if the call is preempted, and something happens to the list, it should
continue to look from that spot until it reaches the end of the list, and
start again ... this isn't an optimal solution, but it should prevent the
problem of the higher channels never getting reused, although, it may lead to
timeout problems if it keeps checking higher channels and low ones are
getting freed (with a long enough list).
Okay ... I'm done ... now it's time for me to step aside, and let someone
smarter correct me ;)
> to devb-umass never returning.  Investigating has shown that the routine is
> interrupts every millisecond on this board.  The loop over the channels
> Or is it a bug that the kernel doesn't handle it correctly?
> of channels without preemption troubles...  Agree?  Disagree?
It's probably server connection id's rather than channels. It is a bug
though: we're supposed to be able to handle up to 32K of them.
 Agree?  Disagree?
Yup.
vector...
Rather than devb-umass, it could be the clients connecting to it as well
that are forgetting close things. If it is scoid's like I think, we can
tell who's doing the opens and the MME folks can check if they've got a
bug there.
	Brian
How can we easily tell who the clients are?  The first thing we thought
of was "pidin fds", but that isn't supported in 6.3.0...
From: Brian Stecher [mailto:community-noreply@qnx.com]
Sent: Thursday, November 06, 2008 11:45 AM
To: ostech-core_os
Subject: Re: open channels: what's a reasonable maximum?
open?  Or is it a bug that the kernel doesn't handle it correctly?
number of channels without preemption troubles...  Agree?  Disagree?
Yup.
bug there.
	Brian
OSTech
http://community.qnx.com/sf/go/post16114
I think it'll have to be a special version of procnto that kprintf's
things out.
	Brian
> To: ostech-core_os
> Yup.
> bug there.
> 	Brian
> http://community.qnx.com/sf/go/post16115
This seems to imply that we should have some sort of generic vector_lookup mechanism to handle preemption, no?
  Agree?  Disagree?
> Yup.
vector...
> bug there.
> 	Brian
cburgess@qnx.com
A vector_lookup isn't a problem - it's O(1). It's people scanning the
vector array: vector_search or, in this case, the traversal looking for
a connection to share with are the issue. I don't think that you can
do a generic mechanism to deal with it.
In this case, there's a fairly trivial fix that can be made at the cost
of not always sharing a connection. Somewhat harder but not impossible,
would be something that picked up the search from where it left off when
the call got preempted.
	Brian
That's what I said ... only in less words. Thank you Brian, for affirming my
belief that there's still hope out there for me ;)
Sorry, vector_search was, of course what I meant. :-)
How about saving the current index, and a generation, in the thp args.
We would then restart the search there, and a change to the vector would
bump the generation.
> 	Brian
cburgess@qnx.com
Two (and 1/2) problems:
As a utility routine, vector_search doesn't know if the calling routine
is using any of args fields already. That could be dealt by adding an
extra parm to the routine that passes in where it's supposed to store
the info.
We don't have a generic mechanism to tell if this is the first time into
a kernel call or it's being restarted due to a preemption - vector_search
wouldn't be able to tell if the args values are valid or not. This one
is a bit tricky - there are a number of corner cases.
(1/2 problem) - we don't have any place right now to store the generation
number on the vector - we'd have to grow the VECTOR structure.
	Brian
> the info.
I was thinking of a new parm (or a new version of vector_search that takes the parm(s))
Yes, I see a few issues there.  It will bear more thinking...
Phooey! :-)
> 	Brian
cburgess@qnx.com
Looking at the trace and at ker_connect.c again...
The vectors being searched in ker_connect_attach() are the active
thread's fdcons and chancons.  So isn't the problem with the client
(MediaPlayer in this case) rather than the server (devb-umass)?
Doug
To: ostech-core_os
Yup.
bug there.
	Brian
OSTech
Sorry, I thought devb-umass was the active process. In that case, yeah,
the problem might be in MediaPlayer and the MME folks should be queried
if it's usual for it to have that many open files/side channels.
	Brian
> Doug
> To: ostech-core_os
> Yup.
> bug there.
> 	Brian
> http://community.qnx.com/sf/go/post16129
