Re: QNX - Please update the 'tr' command-line program!
11/05/2008 1:44 PM
post16013
On Wed, Nov 05, 2008 at 01:41:22PM -0500, Glenn Schmottlach wrote:
> I've been busy porting several open source packages onto the QNX platform. Several of these packages are autoconf/
automake based which means you run a 'configure' script to generate your Makefiles.
> While trying to build the latest glib library for QNX, I ran across this "bug" in the 'tr' command. Apparently, the
QNX version of 'tr' does not support these common character escape codes:
> \character
> A backslash followed by certain special characters maps to
> special values.
> \a <alert character>
> \b <backspace>
> \f <form-feed>
> \n <newline>
> \r <carriage return>
> \t <tab>
> \v <vertical tab>
> So, when the configure script tries to replace newlines (\n) with a space using a command like
> > cat somefile | tr '\n' ' '
> it will instead replace every 'n' with a space (' '). This is unexpected and is a source of many errors in automake/
autoconf configure scripts that are used to build open source packages. Whether this is a "bug" or not, most packages
(certainly commonly built under Linux) expect 'tr' to support these escape codes. Would QNX consider supporting this
behavior in a future release?
This is fixed in 6.4.
