Forum Topic - QDE debugger: Crash at start of application:
Using my QDE 3.0.0 running on windows, I can successfully download to my QNX neutrino v6.3.2 target system (x86).
I can also use the system monitor to view processes etc.
However, if I start my application with /Run/Resume, it terminates with segmentation fault before reaching the main
function.
If I execute the downloaded application in the command line of the target system, it runs ok.
I have a different target system with the same version, where the QDE debugger works ok.
Re: QDE debugger: Crash at start of application
 If you trying to debug you app from IDE and you get these error it could be library mismatch on host and target (i.e.
libc). Usually happened when host running different version of momentics than target.
