Forum Topic - shutdown: (4 Items)
shutdown
There seems to be two shutdown functions.  One in sys/socket.h and one in sys/shutdown.h.  They both take the same kind
of argument. Are they the same?
Can a program linked with the socket library call the shutdown function that can reboot the machine or will endup trying
 to shutdown a socket ;-)
- Mario
Re: shutdown
kind of argument. Are they the same?
trying to shutdown a socket ;-)
They're different.  The imposter's in libshutdown.a and doesn't
appear to be docked AFAICT.  You should get a conflict at link
time if you're trying to bring them both in.
Re: shutdown
> sys/shutdown.h.  They both take the same kind of argument. Are they the same?
>  can reboot the machine or will endup trying to shutdown a socket ;-)
> -seanb
Haven't check on 6.4 but in 6.3.2 sys/shutdown.h will give a compiler error unless stdint.h is included prior to
including sys/shutdown.h.
I guess that's too lake to change the function name in libshutdown, the damage is done?
Re: shutdown
> > -seanb
It's probably possible to change it since it's only in a
static library.  It would mean updating everything that
calls it and a release note.  I'll make a PR.
