Forum Topic - libm broken- serious:
I was told to repost this here by Ryan Mansfield:
I just spent the last 3 days tracking down an issue which turned out to be a problem with the pow function in libm
(pow(x,2.0f) was
returning inf. for small values of x).  I was very suprised (unhappy) at the end of the struggle to find out that this
is a known issue.
Downloading the new libm solved this problem.  I have a few questions
1) how do I identify the version of the libm libraries to find out if this issue is lingering elsewhere.
2) which versions of the libm library have this issue.
3) does QNX not have some mechanism to notify clients when something as critical as the math library being broken is
identified.  We are building mission critical applications and I only ran into this issue by fluke. I would have
expected something like a RECALL being issed for something this severe.
4) do you have a list of other critical issues such as this which exist so I know what else to look out for instead.  I
am now uncomfortable about the devices I have out in the field.
Regards
Thom Allen
Re: libm broken- serious
> problem with the pow function in libm  (pow(x,2.0f) was
> end of the struggle to find out that this is a known issue.
I'll let someone else comment on these...
This bug was not in our system so we did not have visibility to it to take action. As part of the new 6.4 release of the
 OS, we have updated libm and this issue is corrected. We do have a defined process to notify our customers about "
critical" issues but as noted, this was not in our Problem Report system.
> know what else to look out for instead.  I am now uncomfortable about the
With each new release of software, we develop release notes which lists out the important updates/fixes associated with
the release. At this time, we do not have a mechanism to make our internal bug tracking system publicly available but
this is under discussion as part of the future Foundry 27 plans. In the interim, for projects where we are doing
development in the open/live (Kernel project, Networking project...), you are seeing realtime/live bug fixing being done
 and posted for download in realtime.
I am still waiting for an answer on the first 2 items.
I understand the rest of the answer, however the fact that it was fixed in 6.4 means that you were aware of the issue.
This library is sold as part of Momentics and the fact that QNX is marketed as a real-time solution to be used in
mission critial applications (aircraft avionics for instance) I am suprised that a bug in a basic function in the C math
 library doesn't not trigger some special action on your part.
We have been including QNX in our products for over 10 years (closer to 15 I believe) and have always counted on QNX
being a solid base, until now.
Regards
Thom Allen
Hi Thom,
> fixed in 6.4
The questions You are refering to:
You can use 'use -i ...'
/root# use -i  /lib/libm.so.2
NAME=libm.so
DESCRIPTION=Math functions library
DATE=2004/04/29-15:56:30-UTC
STATE=Stable
HOST=osbld
USER=osbuild
VERSION=6.3.0
TAGID=193
From what I see all Your math libs with version=6.3.0 and TAGID=193
are affected. I doesn't matter what version of OS release and patchlevel You run , I mean all the libm's under QNX6.3.x
 , x={0,2} and/or SPX , X={1,2,3} from the same build.
> means that you were aware of the issue.  This library is sold as part of
> Momentics and the fact that QNX is marketed as a real-time solution > to be used
> in mission critial applications (aircraft avionics for instance) I am
> suprised that a bug in a basic function in the C math library doesn't
Thank You.
> to 15 I  believe) and have always counted on QNX being a solid base, >until now.
Please continue.
> Regards
> Thom Allen
Kind Regards,
Jeevan
Thank you for the reply; we will action updating the library in the field.
