Forum Topic - Specifying multiple configure_opts in build-hooks file:
I've run across this problem repeatably in the build-hooks file where I'm assigning various options to the
configure_opts variable. This is more of a shell question but the solution has eluded me.
This works fine:
function hook_preconfigure {
  configure_opts="${configure_opts} CPPFLAGS=-I/hdrs1"
The problem I have is that I'd like to add additional include paths to the CPPFLAGS variable, e.g.
  configure_opts="${configure_opts} CPPFLAGS=-I/hdrs1 -I/hdrs2"
The CPPFLAGS needs to be passed to "configure" with it's arguments quoted. I've tried escaping them . . .
  configure_opts="${configure_opts} CPPFLAGS=\"-I/hdrs1 -I/hdrs2\""
This does NOT work. It seems like my escaped quotes are stripped prior to passing it to configure. Is there some way to
set one of these environment variables (like CFLAGS, CPPFLAGS, etc...) that are passed to configure to contain arguments
 with spaces (and quoted so configure does not try to interpret them)? I'm sure there is an arcane escape sequence I am
missing. Without some work-around, it seems like you can only assign values to flags that do not contain any spaces.
Re: Specifying multiple configure_opts in build-hooks file
> This works fine:
to set one of these environment variables (like CFLAGS, CPPFLAGS, etc...) that are passed to configure to contain
arguments with spaces (and quoted so configure does not try to interpret them)? I'm sure there is an arcane escape
sequence I am missing. Without some work-around, it seems like you can only assign values to flags that do not contain
any spaces.
You can try something like this:
CPPFLAGS="-I/hdrs1 -I/hdrs2"; export CPPFLAGS
in your function hook_preconfigure.
So it would look something like:
Thanks . . . should've thought of that. This approach seems to do the trick for me.
Glenn
