Forum Topic - Interpreting PPC backtrace: (3 Items)
I'm running into an issue with a largeish shared library on PPC where I'm getting a SIGILL when the library tries to
load.
I've made a sample program that simply dlopen's the file and the problem occurs during the library initialization it
seems from the backtrace:
The backtrace is:
Backtrace from load:
#0  0xff213e04 in _SDA_BASE_ ()
   from /home/thomas/mylib.so
#1  0xfe8df944 in frame_dummy ()
#2  0xff06de28 in _init ()
#3  0xfe33c9d4 in init () from /usr/qnx632/target/qnx6/ppcbe/lib/libc.so.2
#4  0xfe33e39c in dlopen () from /usr/qnx632/target/qnx6/ppcbe/lib/libc.so.2
#5  0x480405ac in main (argc=2, argv=0x4803fc24) at load.c:13
This is all running on 6.3.2 and I was wondering if this triggered anyone's mind about a libc or complilation problem I
should be looking for since those init routines come from the OS side.
 Thomas
Re: Interpreting PPC backtrace
load.
> The backtrace is:
I should be looking for since those init routines come from the OS side.
Would you be compiling the the shared oject with the 3.3.5 gcc driver?
And is this C++ ? With or without exceptions?
Ryan Mansfield
load.
>> The backtrace is:
Right on the money.  This is C++, and I'm building with  qcc (qcc
-V3.3.5,ntoppcbe_cpp) but looking at the
compile line (this is a port that likes GCC argument conventions) I'm
passing:
qcc -V3.3.5,ntoppcbe_cpp ... -f no-exceptions ... -f PIC
So, how bad is this?
It is going to be a bear to change things to -shared (to replace -f PIC)
and  to remove -f no-exceptions
(I can switch to ntoppcbe_cpp-ne fairly easily though if the options
won't collide inside qcc).  I'll run
a build to check this out further.
  Thomas
