Forum Topic - M7 + gcc4.2.1: Panic on shm_unlink: (4 Items)
When investigating http://community.qnx.com/sf/discussion/do/listPosts/projects.core_os/discussion.newcode.topc3140 we
created the attached test application.  When allocating more than 0xFF000 (1,044,480) bytes of shared memory, the kernel
 panics when doing shm_unlink().  This does not occur in QNX630.
Are we missing something, or is this a new kernel bug?
Andy
Attachment: Text test_shmem.c 2.91 KB
Re: M7 + gcc4.2.1: Panic on shm_unlink
Yes - this is a bug.
The failing case creates a 1MB mapping, which gets turned into a 1MB section
mapping by the variable page size code. This code was added post-6.3.2
The crash is in cpu_pte_split() where the 1MB section is being split back to
4K page mapping in preparation for clearing the page table entries in the
cpu_pte_manipulate() function.
This operation is being done from a system context when cleaning up the shared
memory object (the shm_unlink removes the last reference to the object), so
data->adp is NULL. The code doesn't check this so it crashes with a null pointer
de-reference.
	Sunil.
kernel panics when doing shm_unlink().  This does not occur in QNX630.
> Thanks,
> Andy
> http://community.qnx.com/sf/go/post9441
> #include <fcntl.h>
> #include <sys/mman.h>
> #include <stdio.h>
> #include <errno.h>
> #include <string.h>
> #include <stdlib.h>
> #include <unistd.h>
> #include <sys/neutrino.h>
> #define MAP_FAILED  ((void *)-1)
> // This is the size of the map we need to allocate
> static const int mapSize = 28 * 1024 * 1024; // Crashes kernel with SEGV
> // This is the smallest size that crashes the kernel
> /*static const int mapSize = (1 * 1024 * 1024) - (4 * 1024) + \
>  *                         512 - 256 - 128 - 64 - 32 - 16 - \
>  *                         8 - 4 - 2 - 1; // Crashes kernel ... 0xFF001
> // This is the largest size that doesn't crash the kernel; anything smaller
> // works
> //static const int mapSize = (1 * 1024 * 1024) - (4 * 1024); // Works ... 0xFF000
> static const char * testPath = "/dev/shmem/test";
> int main( int argc, char *argv[] )
>    int fd;
>    unsigned int i;
>    unsigned char* addr = MAP_FAILED;
>    fprintf( stderr, "Attaching to shared map \"%s\" of size %d (0x%x) bytes.\n",
>             testPath, mapSize, mapSize );
>    // Failing to do this will cause an immediate Memory Fault
>    if (ThreadCtl(_NTO_TCTL_IO, 0) != EOK)
>       perror( "ThreadCtl" );
>       return EXIT_FAILURE;
>    fprintf( stderr, "ThreadCtl  ok\n" );
>    if( unlink( testPath ))
>       // It's fine if the file doesn't exist
>       if( errno != ENOENT )
>          perror( "unlink" );
>    fprintf( stderr, "unlink     ok\n" );
>    fd = shm_open( testPath, O_RDWR | O_CREAT, 0777);
>    if( fd == -1 )
>       perror( "shm_open" );
>    fprintf( stderr, "shm_open   ok\n" );
>    if( -1 == shm_ctl( fd,
>                       SHMCTL_ANON | SHMCTL_PRIV | SHMCTL_GLOBAL,
>                       (_uint64) 0,
>                       (_uint64) mapSize ))
>       if( ENOSYS == errno )
>          // ENOSYS is telling us that we already did a shm_ctl, and it can only
>          // be done once.
>          fprintf( stderr, "shm_ctl  already run (ok if current size fits)\n" );
>       else
>          perror( "shm_ctl" );
>          close(fd);
>    fprintf( stderr, "shm_ctl    ok\n" );
Glad to know you already know where the problem lies.  Is there a place I can track the status of this bug?  Thanks for
providing the detailed analysis!
--Andy
It's PR59031 in our PR database.
I committed the fix today as revision 171000 in the svn trunk repository.
	Sunil.
for providing the detailed analysis!
> --Andy
> http://community.qnx.com/sf/go/post9478
