Re: TraceEvent got permission denied during trace buffer allocation (QNX 8.0)
06/17/2025 2:54 AM
post122665
Thank you for your reply!!
I have finally integrate the TraceEvent() on QNX 8.0 successfully!
For more people can reference, here is the summary of the total change from 7.0 to 8.0:
- **Proactive Tracing**: Registration of the trace event process with the kernel is required using `
_NTO_TRACE_LOGGER_ATTACH`.
- IO and interrupt privileges are no longer necessary for trace event operations.
- **Buffer Management**: Use `_NTO_TRACE_WAITBUFFER` to check for buffer availability. Each CPU now has its own
dedicated buffer set.
- `InterruptHookTrace` is deprecated for trace event interrupts.
- The second parameter of `_NTO_TRACE_ALLOCBUFFER` now specifies per-CPU buffer count instead of total buffer count.
- **Filtering Capabilities**: Dynamic rule filtering is no longer supported.
- Only static rule filters and post-processing filters are available.
- **Simplified Buffer Allocation**:
- `_NTO_TRACE_ALLOCBUFFER` now returns a direct pointer to user space memory.
- Manual memory mapping of the returned address is no longer required.
