Forum Topic - Shutdown Message isn't printed in console on QNX 7.0: (10 Items)
we try with the following configuration and wdt disable and there wasn´t any dump or trace on serial console
[image=0x10800000]
[virtual=armle-v7,raw +compress] .bootstrap = {
	startup-imx6x-apalis -m -vvvvv
	[+keeplinked]
	kdumper
    PATH=/proc/boot:/bin:/usr/bin:/opt/bin/sbin:/usr/sbin LD_LIBRARY_PATH=/proc/boot:/lib:/usr/lib:/lib/dll:/lib/dll/pci
:/opt/lib procnto-smp-instr -v
thanks.
Re: Shutdown Message isn't printed in console on QNX 7.0
There wouldn't be any message if it's a watchdog reset. The hardware resets the processor without involving the OS at
all.
If the board supports it you can install a watchdog interrupt handler, though that still won't (by itself) cause a
shutdown message.
--Elad
> the processor without involving the OS at all.
> that still won't (by itself) cause a shutdown message.
> --Elad
Hi Elad,
The watchdog is disabled, we crash the system forcing a segmentation fault (writing invalid address throw mmap function)
, the qnx kernell stop scheduling but no shutdown message is printed.
Sorry, I misunderstood. Thought you said it was a watchdog reset.
What do you mean by writing an invalid address through mmap()? I assume you were mapping some physical memory and trying
 to crash the system that way, but it really depends on what address was used. For example, writing to a bank that's not
 powered will often result in a bus lockup.
--Elad
> were mapping some physical memory and trying to crash the system that way, but
> that's not powered will often result in a bus lockup.
> --Elad
Exactly , we write invalid address (trying to force a bus lockup, segmentation fault, etc) until QNX scheduler stop
working (system freeze, no software or hardware reset) , base on  https://www.qnx.com/developers/docs/7.1/#com.qnx.doc.
neutrino.technotes/topic/proc_dump.html , a shutdown message should be printed on serial console, but in this case qnx
freeze without any message or information.
You only get a shutdown message if the processor raises an exception while the kernel is executing. If you just get the
hardware into a bad state there is no guarantee that such an exception will occur. That's what watchdogs are for.
--Elad
>  kernel is executing. If you just get the hardware into a bad state there is
> --Elad
but, for example if you rise a "data abort exception" in a process (user space), the process is kill and the core dump
file is generated but the QNX scheduler keeps working, now we found in our system a condition unknow for us at the
moment where QNX stop scheduling and the system freeze, how can we related this condition to an microcontroller
exception (like bus lockup, or segmentation fault)?
what about exceptions on kernell space?
how can we debug this condition?
thanks
If the hardware stops functioning (such as in the case of a bus lockup) then there is nothing the kernel can do to
detect this problem, let alone to rectify it. The kernel needs the hardware in order to execute - it's not special in
this sense. Cases like these require specialized debug facilities such as JTAG and/or an embedded trace buffer (ETB).
--Elad
> there is nothing the kernel can do to detect this problem, let alone to
> special in this sense. Cases like these require specialized debug facilities
> --Elad
thanks Elad,
In the case of  segmentation fault on an interruption, what´s the kernell behavior?
If you have an ISR, and it faults, then the fault will be caught, the kernel will display the shutdown message and
invoke the reboot callout.
One more reason not to use ISRs...
--Elad
