QNX 6.6.0 file system encryption , locked domain files are not encrypted
06/14/2024 1:03 PM
post122561
The x86 platform with Patch id 4277 installed and locked domain files are not encrypted.
I am attaching sequence of commands to test FS encryption. After the domain is locked i am still able to read the
content of the file in that domain. My quess is that the sequence of event of my test is not correct.
The sequence of command is listed below:
# fdisk /dev/hd1 add -t 178 -p 100
# mount -e /dev/hd1
# mkqnx6fs -E /dev/hd1t178
mkqnx6fs: filesystem block size must be 4k when file data encryption is enabled
# mkqnx6fs -E -b 4096 /dev/hd1t178
All files on /dev/hd1t178 will be lost!
Confirm filesystem re-format (y) or (n): y
Format fs-qnx6: 3863620 blocks, 120768 inodes, 8 groups
# mount -vvvv -t qnx6 -ocrypto=enable /dev/hd1t178 /enc2
Parsed: mount from [/dev/hd1t178] mount on [/enc2] type [qnx6]
exec: mount_qnx6 -o crypto=enable /dev/hd1t178 /enc2
Using internal mount (mount_qnx6 not found)
Type [qnx6] Flags 0x00000000
Device [/dev/hd1t178] Directory [/enc2]
Options [crypto=enable]
# fsencrypt -vv -c check -p /enc1
Logging verbosity set to 2
# fsencrypt -vv -c check -p /enc2
ENCRYPTION_CHECK(Path:'/enc2') INTERNAL NOTICE: (12) - 'Supported'
# fsencrypt -vv -c create -r -t1 -d20 -p/enc2 -k+password
CREATE_DOMAIN(Path:'/enc2', Domain:20, Type:1) SUCCESS
UNLOCK_DOMAIN(Path:'/enc2', Domain:20) SUCCESS
OK
# touch /enc2/test1
# touch /enc2/test2
# fsencrypt -vv -c setup -k:20:1:0::/enc2
SUCCESS
# touch /enc2/test3
# echo "test4" > /enc2/test4
# fsencrypt -vv -c lock -d20 -p/enc2
# cat /enc2/test
test1 test2 test3 test4
# cat /enc2/test4
test4
Please advice
Janusz
