Re: How not to pollute app w/proprietary API calls?
05/22/2008 11:25 AM
post8385
Hi Jonathan,
No, POSIX doesn't specify interfaces for attaching to interrupts. In
general dealing with
interrupts is very OS specific. At best you can write wrapper
routines/macros.
Jonathan Juniman wrote:
> In the Neutrino library reference, some functions are classified as Posix,
but others are classified as Neutrino (e.g. InterruptAttach). Does that mean
no Posix function exists for attaching interrupts? I would like to avoid the
use of proprietary API calls in my code to the extent possible.
> http://community.qnx.com/sf/go/post8380
cburgess@qnx.com
05/22/2008 12:02 PM
post8389
> Posix, but others are classified as Neutrino (e.g. InterruptAttach).
> Does that mean no Posix function exists for attaching interrupts?
> I would like to avoid the use of proprietary API calls in my code to
There's usually a note in the library reference entry giving the equivalent
POSIX functions and saying you should use those (where they exist) and
the "See Also:" section would have the POSIX API's listed as well.
