Forum Topic - QNX 7.1 Neutrino screen output RGB value range is limited to [0x10~0xEB]: (2 Items)
I connected QNX 7.1 HDMI output to an Xilinx video capture device and found that the pixel RGB value range is limited to
 [0x10~0xEB] but not [0x00~0xFF]. For example, when I display red (0xFF0000) color on QNX, we got color (0xEB1010) on
video capture device, and when we display black (0x000000) color, we got color (0x101010).
Some pixels value mapping
Pixel on QNX  Pixel on video capture
00            10
01            10
02            11
03            12
04            13
05            14
06            15
07            16
08            16
09            17
0A            18
0B            19
0C            1A
0D            1B
0E            1C
FD            E9
FE            EA
FF            EB
However, when we connected ubuntu/Window10 HDMI output to the same video capture device, everything works fine.
When I used screenshot utility to capture the display on QNX 7.1, we got the correct color(the RGB range is [0x00~0xFF])
The graphics.conf is:
begin khronos
  begin egl display 1
    egl-dlls = libglapi-mesa.so libEGL-mesa.so
    glesv1-dlls = libglapi-mesa.so libGLESv1_CM-mesa.so
    glesv2-dlls = libglapi-mesa.so libGLESv2-mesa.so
    gpu-dlls = gpu_drm.so
  end egl display
  begin wfd device 1
    wfd-dlls = libwfdcfg-intel-generic.so libWFDintel-drm.so
    # Run "drm-probe-displays" to list the available displays and pipelines,
    # and "use $GRAPHICS_ROOT/libWFDintel-drm.so" for more information on
    # these driver-specific settings.
    # Here is displays map for DH370:
    # display 1: DisplayPort (DP-1)
    # display 2: DisplayPort (DP-2)
    # display 3: HDMI-A (HDMI-A-1)
    # display 4: DisplayPort (DP-3), default
    # display 5: HDMI-A (HDMI-A-2)
    # display 6: DisplayPort (DP-4)
    # display 7: HDMI-A (HDMI-A-3)
    # Pipeline IDs 1 to 9 are used for DRM CRTCs.  One should be assigned
    # to each display that will be used.
    pipeline1-display = 1
    pipeline2-display = 2
    pipeline3-display = 4 # this is the display id which identified by drm-probe-display, the only hdmi output on DH370
  end wfd device
end khronos
begin winmgr
  begin globals
    default-display = 4 # the default display id, 4 is the only one hdmi output on DH370
    # Adjust the stack size of Screen's resmgr threads.  The default size
    # is insufficient for blitters/compositors using Mesa (e.g., gles2blt).
    stack-size = 65536  # in units of bytes
    blit-config = inteldrm
    alloc-config = inteldrm
    requests-logsize = 65536
    blits-logsize = 4096
  end globals
  begin display 1
    video-mode = 1920 x 1080 @ 60
    # Adjust the stack size of Screen's composition thread; required when the
    # display's framebuffer uses Mesa (e.g., "usage = gles2"), as noted above.
  end display
  begin display 2
  end display
  begin display 4
  end display
  begin class framebuffer-1
    display = 1
    pipeline = 1
    format = rgba8888
    usage = inteldrm
  end class
  begin class framebuffer-2
    display = 2
    pipeline = 2
    format = rgba8888
    usage = inteldrm
  end class
  begin class framebuffer-3
    display = 4
    pipeline = 3
    format = rgba8888
    usage = inteldrm
  end class
end winmgr
/root# cat...
Re: QNX 7.1 Neutrino screen output RGB value range is limited to [0x10~0xEB]
It seems that QNX intel drm output through HDMI is RGB limited (0x10~0xEB) but not RGB full (0x00~0xFF). So how can I
set RGB full for intel drm driver?
