Forum Topic - QNX 7.0 invalid behavior of mmap_device_memory:
The call mmap_device_memory returns NULL !
   if (ba[1].addr == pci_asType_e_MEM)
           BAR[1]= mmap_device_memory( 0, 0x40000, PROT_READ|PROT_WRITE|PROT_NOCACHE, MAP_PHYS  | MAP_SHARED,  ba[1].
addr );
	   if ( BAR[1] == MAP_FAILED )
		perror( "mmap_device_memory for physical address 0x40000 failed" );
		exit( EXIT_FAILURE );
     else return(EXIT_FAILURE);
The PCI config space has been correctly read: It schows all data  as shown by the pci-tool!!
Whats the reason for that invalid behavior of mmap_device_memory??
Best Regards
Armin
Re: QNX 7.0 invalid behavior of mmap_device_memory
The only case mmap() returns NULL is with MAP_FIXED, which is not the case here.
What architecture are on? 32-bit or 64-bit?
By the way, mmap_device_memory() is a trivial wrapper around mmap(). There is really no reason to use it (but that has
nothing to do with this issue).
--Elad
I used at first mmap and it returns also a NULL Pointer!
Armin
            resp = pci_device_map_as(hdl, &ba[1], &xlate);
            if (resp == PCI_ERR_OK)
                BAR[1] = (unsigned char *) mmap64(0, 0x40000, PROT_NOCACHE | PROT_READ | PROT_WRITE, MAP_PHYS |
MAP_SHARED, NOFD, xlate.addr );
            else return(resp);
            mmap64 returns also a NULL pointer, mapping a smaller size (4096) works for an other driver! 0x40000 ->  ~
250kB physical memory
            Armin
could you please attach the code here? It's interesting, it is a fundamental piece of code, if this is wrong, I don't
know how many system can even boot.
Hi Armin,
I didn't receive an answer to the question of which architecture this is on. Also, what is the type of BAR[1]? How do
you check that mmap() returned NULL, as it doesn't appear in the code.
--Elad
Elad,
what is the best way to increase the initial heap size of the prozess manager in an generic x86_64 buildfile??
My suspicion is that the size of the initial heap - managed by the prozess manager - is too small!
have a look to my initial posting. It shows 100% of the critical code!
Is it really return NULL, not MAP_FAILED, the code test MAP_FAILED.
what errno?
yes, it returs a NULL pointer and not the error code!
Armin
System:: X68_64, Intel CPU,
definition of BAR ->  void * BAR[6]  ... it' just a typless pointer array
And please ....  avoid killing arguements against this problem. There is a failure.!
The same code for mapping of 4096 byte is working already since more than 1 year at customer sites.
> failure.!
Hi Armin,
Sorry. I use this function with the RocketPort x86_64 driver under 7.04 driver and it works fine for me using the
address from the PCI (IRQ's from the PCI is a different story! :_) )
I have yet to build this driver on 7.1 (hoping to soon)
There must be some simple explanation for what you are describing.
Can you please provide a simple snippet of code that can be used to verify this behaviour you are experiencing?
I would be very concerned if there is something lurking in this and especially if it were to happen on the ARM platforms
Feel free to email directly if you want.
Cheers,
Geoff.
I'm using as a test system the generic x86_64 BSP. No changes made
Are there any restrictions in usage of memory?
I'm wondering if there is something else (hardware related?) involved here. I can't remember right now what the
underlying hardware was that I used (one was a Gigabyte m/board) but like you I used the generic x86_64 BSP.
Like I said I had no problems with either.
Also, the memory I am accessing is not large. As I recall only 128 bytes mapped to an FPGA (also called "dual port
memory"). Whatever, it all works.
Geoff.
Nobody is trying to kill anything here. We are asking questions so that we can help.
The initial code snippet does not provide all of the information, as it does not show the type of BAR[1] and it doesn't
show where you determine that BAR[1] is NULL. Lichun and I thought that perhaps you are truncating a 64-bit virtual
address to a 32-bit value.
I have been working with (and on) this memory manager for the past 8 years and I can assure you that it doesn't return a
 virtual address of 0 unless you specify MAP_FIXED. The code very clearly restricts user addresses to 4K-512GB. As
Lichun pointed out, if mmap() were ever to return NULL then many things would not work.
mmap() has nothing to do with the heap, either of your user process or of the process manager.
Just to be absolutely sure, can you add some debugging to the code immediately after mmap() returns that prints the
virtual address as a 64-bit pointer?
@Geoff - this cannot have anything to do with the hardware. No matter what the hardware does, the selection of a virtual
 address is purely a software mechanism. The memory manager just finds a hole in the virtual address space of the
appropriate size and uses it. Any failure of mmap(), for whatever reason, should result in the function returning
MAP_FAILED.
I'm more than happy to help you find the problem. Let's keep things friendly ;-)
--Elad
[some snipped]
>  hardware does, the selection of a virtual address is purely a software
> of the appropriate size and uses it. Any failure of mmap(), for whatever
> reason, should result in the function returning MAP_FAILED.
I was grasping! :-)
A lot of this stuff is PFM to me and I'm glad you're dealing with it and I'm not! :-) I just use it...
G.
> --Elad
Hi Elad,
 mmap_device_memory() and mmap/) are working as expected!
I did a typo and compared a baseregister addr against a baseregister type ... realy stupid.
The resource manager for the fiedlbus called INTERBUS is now working for QNX 7.0
Thanks for your pacience
Armin
BTW. the Interbus adapter is an "old"  PCI 2.1 cardbus adapter :)
Armin
No problem.
I'm glad you found the issue.
--Elad
