Per client notification from resource manager?
08/31/2020 10:01 AM
post120917
I have a resource manager that gathers data at modest rates from an A/D (as in 500Hz). It's high enough that I'd rather
only notify clients when an event happens and have them come grab relevant data and not send all samples to all clients
. For example, each client might specify a trigger level for a signal crossing. I'd like to support io_notify in this
resource manager, because some clients will use select(). The io_notify approach is well explained in the documentation
and for the standard iofunc_notify_trigger, this works well.
My question is, if each client has its own OCB in the resource manager (which I've expanded to include this info) and
I've added a list of all open clients (OCBs) in the device attribute (again, all nicely explained in the docs!), then is
there a proper way to call iofunc_notify_trigger() on a per client basis, because not all clients will need
notification at the same time. It seems like the "strict" version is what I'm looking for, but it wants a ctp - can I
get this from the OCB? (I think I know how to do this in a QNX specific way with MsgDeliverEvent, but at least for some
clients, I'd like to stick to the POSIX io_notify).
Thanks!
