Re: Is this a an valid configuration file
07/11/2020 5:14 AM
post120836
> I had already replied to previous posts that we do not explicitly exclude any
> version of PCI device.
Sorry, it isn't true for versions of QNX 6.x.
The support of devices based on the parallel PCI bus is a littlebit lousy under QNX 7.x
> The problem description you provide does not give any real insight into what
> specific problem it is you are having.
The fact that we have to create speciallized OS images for parallel bus PCI devices could be better.documented!!
> Perhaps collect some pci-tool output, slog2info etc and we may be able to
> assist you
My question was:"A fter creating an adapted OS Image - for manually assigning an IRQ - are parallel bus PCI devices
fully supported??".
BTW ... long time ago, I provided a screendump of pci-tool showing that no IRQ has been assigned!!
I haven't seen hints about PCI config files a.s.o.
Regards
Armin
07/26/2020 5:07 AM
post120868
Michael Kisel wrote:
> I had already replied to previous posts that we do not explicitly exclude any version of PCI device.
> The problem description you provide does not give any real insight into what specific problem it is you are having.
The output of pci-tool isn't correct. It doesn't show the real assigned
IRQ and its pin!! Please see my last posting!
Also: the assignment of IRQs by the pci-server is weak documented ...
however its seems not yet implemented!
That means at the end -> the support of local bus PCI devices is
currently not existent!
Armin
> PS: slog2info etc and we may be able to assist you
really ?
> http://community.qnx.com/sf/go/post120835
