Hi I want to use gdb to debug a hang issue I was referring to this link http://www.qnx.com/developers/docs/7.0.0/index.html#com.qnx.doc.neutrino.prog/topic/using_gdb.html Is it necessary to have Momentics to connect GDB tool ?
http://www.qnx.com/developers/docs/7.0.0/index.html#com.qnx.doc.neutrino.prog/topic/using_gdb_SettingTarget.html target qnx <ip:port> Cheers ________________________________________ From: Sobin Thomas [community-noreply@qnx.com] Sent: Thursday, September 19, 2019 05:47 To: ostech-core_os Subject: How to connect GDB to the target Hi I want to use gdb to debug a hang issue I was referring to this link http://www.qnx.com/developers/docs/7.0.0/index.html#com.qnx.doc.neutrino.prog/topic/using_gdb.html Is it necessary to have Momentics to connect GDB tool ? _______________________________________________ OSTech http://community.qnx.com/sf/go/post119962 To cancel your subscription to this discussion, please e-mail ostech-core_os-unsubscribe@community.qnx.com
Hi Thanks, but i need more info than that like how to load the agent
you will need qconn and pdebug on the tareget then start qconn http://www.qnx.com/developers/docs/7.0.0/index.html#com.qnx.doc.neutrino.user_guide/topic/security_qconn.html it should default to port 8000 ________________________________________ From: Sobin Thomas [community-noreply@qnx.com] Sent: Friday, September 27, 2019 12:02 To: ostech-core_os Subject: Re: RE: How to connect GDB to the target Hi Thanks, but i need more info than that like how to load the agent _______________________________________________ OSTech http://community.qnx.com/sf/go/post120001 To cancel your subscription to this discussion, please e-mail ostech-core_os-unsubscribe@community.qnx.com
