RE: Installing QNX with Hyper-V [Student]
09/17/2019 1:19 PM
post119949
OK, so if the easy way is blocked, you need to proceed with the slightly harder way. You will need to build an IFS
(image file system), which has the bootable QNX image, including startup, the kernel, various drivers and services. The
you will need to create a disk for Hyper-V, format it with QNX6 FS, copy the IFS under /.boot and run it.
This may sound complicated, but should be much better explained in the documentation for the x86_64 generic BSP
available on Software Centre.
--Elad
Sent: September-17-19 1:09 PM
To: ostech-core_os
Subject: Re: RE: Installing QNX with Hyper-V [Student]
Not that I am aware. I tried everything under my belt for 3-4h. Hyper-V does not accept .vmx files. Also, nothing worked
to transfer a .vmx into a .iso.
OSTech
http://community.qnx.com/sf/go/post119947
