Forum Topic - Using the precision time protocol (PTPd) on QNX SDP 7.0:
I have a problem statement that requires time synchronization between a Master (Microcontroller) and
Slave(Microprocessor). The slave runs on QNX and time needs to be synchronized between the two.
The Master would sent PTP frames over Ethernet and I need to use PTPd to use these packets and synchronize the time on
Slave side.
Below are the questions that I have:
1. Does PTPd parse the message from the Ethernet packet ?
2. Does it work stand-alone and synchronize the time periodically?
