Robust Mutexes under QNX 7.0
02/16/2018 3:18 PM
post118589
I have a question about how robust mutex's work under QNX 7.0.
I create my mutex as (lots of error checking omitted for simplicity):
pthread_mutex_t mMutex;
pthread_mutexattr_t mMutexAttr;
// Robust and recursive
pthread_mutexattr_init(&mMutexAttr);
pthread_mutexattr_setrobust(&mMutexAttr, PTHREAD_MUTEX_ROBUST)
pthread_mutexattr_setrecursive(&mMutexAttr, PTHREAD_RECURSIVE_ENABLE)
// Initialize
pthread_mutex_init(&mMutex, &mMutexAttr);
In my lock() routine my code is:
// Acquire the mutex
int retVal = pthread_mutex_lock(&mMutex);
if (retVal != EOK)
if (retVal == EOWNERDEAD)
pthread_mutex_consistent(&mMutex);
printf("Mutex::lock() - Owner died holding mutex. Fixing state\n");
else
printf("Mutex::lock() - Error %s while trying to lock mutex! Mutex not locked!", strerror(retVal));
else
// Locked do some processing
Now I'm in a multi-threaded application (not multi-process) and I see the following behavior:
1) Thread A locks the mutex
Thread B blocks when trying to lock.
Kill Thread A.
Thread B never acquires the mutex (I thought the robustness would wake B and let it acquire the Mutex with the
EOWNERDEAD return code so I could cleanup and continue) and I'm deadlocked.
2) Thread A locks the mutex
Kill Thread A
Thread B tries to lock. It gets return code of EINVAL not EOWNERDEAD? Once again my process is effectively broken.
So are robust mutexes implemented under QNX 7 and if so am I doing something wrong code wise to make them work? Or do I
have to use the SyncMutexEvent() methodology instead (is there sample code)? My preference is Posix over QNX specific
code for portability reasons.
TIA,
Tim
Re: Robust Mutexes under QNX 7.0
02/16/2018 3:25 PM
post118590
Robust mutexes work across processes, not threads. It is only when a
process dies that the wakeup mechanism kicks in.
Robust mutexes are not supposed to recover from errors in your code
(which would be the inter-thread case - why do you have a thread exit
while holding a mutex?) but from situations you have less control over,
such as another process going down.
--Elad
> // Initialize
> if (retVal != EOK)
> state\n");
> else
> else
> Kill Thread A.
> wake B and let it acquire the Mutex with the EOWNERDEAD return code
> Kill Thread A
> something wrong code wise to make them work? Or do I have to use the
> preference is Posix over QNX specific code for portability reasons.
> TIA,
> Tim
> http://community.qnx.com/sf/go/post118589
> To cancel your subscription to this discussion, please e-mail ostech-
> core_os-unsubscribe@community.qnx.com
02/16/2018 3:40 PM
post118591
I had no idea that kind of limitation (process only) is placed on it.
We have a fairly complex system where many objects have internal mutexes to protect their internal state. At the moment
it means we can't ever terminate a thread for any reason because we can't know if that thread currently owns any mutexes
. So in effect every thread either lives forever or must terminate on it's own in a consistent state.
While I agree in theory all threads should be able to do the above, sometimes that's not possible and some cases it's
far simpler to terminate and respawn instead of trying to put everything back into a 'prior state' so we are terminating
threads.
I'll assume spawning as detatched doesn't help.
Tim
> --Elad
02/19/2018 3:29 AM
post118594
Maybe try to use pthread_cancel() to set a thread termination pending, and then use pthread_cleanup_push()/
pthread_cleanup_pop() to register per-thread cleanup routines for explicitly freeing resources. Of course, if you are
using third-party library code that spawns threads internally that wouldn't help, but it does give you more control over
your own threads. Placing pthread_testcancel() at strategic points in the code might help, too
I think that the threading model is desigend with the idea in mind that each thread is in itself relatively simple,
robust and self-contained. Not always possible to put into practice, I know.
Albrecht
02/19/2018 9:52 AM
post118595
The question then becomes how many places have to have that cancel code added to them to handle a potential cancel
request.
What if instead I spawned a dummy process for every Mutex (I can do this easily because all our Mutexes come from a
Mutex wrapper class we created). The dummy process just wakes up once a second and acquires then releases the mutex to
validate it's state is good and fixes it if EOWNERDEAD is returned. Would that solve my problem (other than the
silliness of spawning potentially dozens of these dummy processes).
According to the doc's:
http://www.qnx.com/developers/docs/7.0.0/index.html#com.qnx.doc.neutrino.lib_ref/topic/p/pthread_mutexattr_getrobust.
html
"If the process containing the owning thread of a robust mutex terminates while holding the mutex lock, the next thread
that acquires the mutex is notified about the termination by the return value EOWNERDEAD from the locking function. If
the owning thread of a robust mutex terminates while holding the mutex lock, the next thread that acquires the mutex is
notified about the termination by the return value EOWNERDEAD. "
what I did *should* be working. So it's either a bug or the doc's need to be updated to remove that second sentence
about threads.
Tim
RE: Robust Mutexes under QNX 7.0
02/20/2018 7:20 AM
post118597
Robust mutexes cannot work across threads within the same process for the simple reason that the kernel doesn't always
know that thread A holds mutex B. An uncontended mutex lock operation doesn't go through the kernel, it is a simple
atomic operation in user mode. Therefore a thread can go away while holding one or more mutexes an the kernel is none
the wiser.
A thread exiting while holding a mutex lock is an application bug. The OS cannot be expected to fix application bugs.
And please, whatever you do, don't use pthread_cancel() - that will make things much worse.
--Elad
From: Tim Sowden(deleted) [community-noreply@qnx.com]
Sent: February-19-18 9:52 AM
To: ostech-core_os
Subject: Re: Robust Mutexes under QNX 7.0
request.
html
about threads.
Tim
OSTech
http://community.qnx.com/sf/go/post118595
Re: RE: Robust Mutexes under QNX 7.0
02/20/2018 11:59 AM
post118599
In that case this line in the Doc's (taken verbatim from POSIX robust mutex definitions) is totally wrong and should be
removed.
"If the owning thread of a robust mutex terminates while holding the mutex lock, the next thread that acquires the
mutex is notified about the termination by the return value EOWNERDEAD. "
After doing some reading I think I've found another way to do what I want. GCC supports throwing C++ exceptions in
signal handlers so I'm going to raise a signal on the thread I want to cancel and then throw an exception in the signal
handler. That exception will let me unwind the stack which will release any mutex's (the class they are in is RAII) and
then the thread can exit in the top level try/catch block.
Tim
> simple reason that the kernel doesn't always know that thread A holds mutex B.
> simple atomic operation in user mode. Therefore a thread can go away while
> holding one or more mutexes an the kernel is none the wiser.
> cannot be expected to fix application bugs. And please, whatever you do, don't
> --Elad
02/20/2018 1:26 PM
post118600
Elad, I would be much interested to understand why pthread_cancel() is not a good idea to use.
Albrecht
02/20/2018 1:32 PM
post118601
It's not impossible to use pthread_cancel() correctly, but it is very
hard to do so. You have to account for all of the state that is carried
by the thread, both explicit and implicit, and make sure it all gets
cleaned up. That makes for a very error prone implementation. It's akin
to jumping out of a long function in the middle - possible, but very
tricky.
--Elad
> Thanks,
> Albrecht
> http://community.qnx.com/sf/go/post118600
02/22/2018 10:11 AM
post118612
As far as I can tell our implementation is POSIX-compliant. The
relevant part of the spec mandates that robust mutexes allow a thread
to detect an inconsistent state if the owning *process* exits.
Detecting a thread exit while holding a mutex is optional.
http://pubs.opengroup.org/onlinepubs/9699919799/functions/pthread_mutex
attr_getrobust.html
We could have implemented the optional behaviour, but only at the cost
of making every mutex operation enter the kernel.
I will ask for the documentation to clarify this point.
--Elad
> mutex definitions) is totally wrong and should be removed.
> mutex lock, the next thread that acquires the mutex is notified about
> want. GCC supports throwing C++ exceptions in signal handlers so I'm
> an exception in the signal handler. That exception will let me unwind
> RAII) and then the thread can exit in the top level try/catch block.
> Tim
> > for the
> > holds mutex B.
> > it is a
> > away while
> > The OS
> > you do, don't
> > --Elad
> http://community.qnx.com/sf/go/post118599
02/26/2018 3:20 AM
post118618
Hello Tim,
I had recently another kind of problem with a robust mutex (in ported legacy code). It seems to be a bug, but I don't
know how to verify that because I don't have a QNX support deal.
So my current recommendation is: do not use PTHREAD_MUTEX_ROBUST on QNX!
My scenario is (attached a sample code):
1. one thread is blocked on pthread_cond_wait()
2. another thread cancels the thread
3. problem: the thread never quits (application blocks forever at pthread_join()).
In this scenario, my solution is to use pthread_cleanup_push() to handle mutex releasing.
Attachment: |
cp1.c
2.13 KB
02/26/2018 3:25 AM
post118619
I replied before seeing the whole discussion thread .. I think this was clarified already. Sorry for noice.
02/26/2018 7:16 AM
post118620
I think that what you observed is a real bug that was fixed for 7.0.1.
--Elad
Sent: February-26-18 3:25 AM
To: ostech-core_os
OSTech
http://community.qnx.com/sf/go/post118619
02/26/2018 8:08 AM
post118621
Hi Elad,
Thanks for info, I seem to be using 7.0.0.
Lauri
> --Elad
> From: Lauri Kaila [community-noreply@qnx.com]
> To: ostech-core_os
