Forum Topic - Getting CPU ID: (5 Items)
Getting CPU ID
Hi
Is there a way to get the CPU ID using the QNX API?
I found how to tie to a specific CPU, but I couldnt find any documentation on getting the CPU number of the current
thread
Re: Getting CPU ID
Just to be clear - you're looking for the equivalent of Linux's getcpu(2) or glibc's sched_getcpu(3) ?    I had a
similar goal in an implementation of ntp's nanosecond kernel for an SMP system.   I couldn't find a nicely packaged
solution.   You might be able to get what you want by running the DCMD_PROC_TIDSTATUS command on one's own thread and
checking the last_cpu field.   I needed something safe to run even in an ISR (so I could capture timestamps with the
lowest possible latencies), so I never investigated that solution further.
-Will
Re: Getting CPU ID
Hi Will
Yes, that is what I needed!
I ended up using a platform specific solution, reading one of system registers indicating the CPU ID
Re: Getting CPU ID
> Hi Will
Can you notice, what register already contain cpu number you read?
I just found how to read Lapic Id and have to transform it into cpu id, using smpinfo from syspage - they are generally
not the same.
Re: Getting CPU ID
Hi Artem,
On x86 as of the QNX version I'm using, it's stored in the task register, which you can retrieve via the STR instruction
.   I believe the full expression is:
cpunum = ( TR / 8 ) - 32
where TR is the value in the task register.
I haven't personally investigated any other architectures yet.
-Will
