Forum Topic - Resource manager using thread pool in C++:
I have a couple of questions concerning development of thread pools in C++.
I am developing a resource manager using thread pool in C++, it is all incapsulated in a Comm class. But when set up the
 thread pool functions, it returns me a casting error, for example:
Function definition:
THREAD_POOL_PARAM_T * Comm::WaitForMessage(THREAD_POOL_PARAM_T *ctp);
Then when initialising the thread_pool_attr_t:
tp_attr.block_func = Comm::WaitForMessage;
Moments give me an error like:
cannot convert 'Comm::WaitForMessage' from type 'resmgr_context_t* (Comm::)(resmgr_context_t*) {aka _resmgr_context*
(Comm::)(_resmgr_context*)}' to type 'resmgr_context_t* (*)(resmgr_context_t*) {aka _resmgr_context* (*)(_resmgr_context
Another thing, as far as the documentation and headers lead me to think, the THREAD_POOL_PARAM_T *, coulee be a void
pointer (as defined in the dispatch.h header), allowing me to transit any kind of structure as parameters and returns of
 the thread pool functions (allocating resources, blocking, handling, etc).
But when I try this:
THREAD_POOL_PARAM_T * Comm::ContextAlloc(THREAD_POOL_HANDLE_T *handle)
    //  Stablish connection to CAN server
    CommServerStruct *comm_server = new CommServerStruct;
    comm_server->can_coid = open(CAN_SERVER_PATH, O_WRONLY);
    return ((void*)comm_server);
Moments give me the error:
invalid conversion from 'void*' to 'resmgr_context_t* {aka _resmgr_context*}' [-
 fpermissive]
Could anyone please guide me in what am I doing wrong?
Re: Resource manager using thread pool in C++
Its seems to me more a C++ problem :-)
Please post some more code...
anyway, I suppose tp_attr is a thread_pool_attr_t ...
this one:
If You want to register a class member as a call-back function, like in C, the way
shown is not correct. A method is NOT like a function.
For Your second question, in C++ You can not do
but if comm_server is a void*
    return ( (THREAD_POOL_PARAM_T*)comm_server);
or, if You want a void* , You have to change member declaration.
Try this one (I'm not sure it works)
class Comm{
public:
	thread_pool_attr_t	tp_attr;
	public:
	Comm(){
		tp_attr.block_func = WaitForMessage;
	~Comm(){};
	static THREAD_POOL_PARAM_T* WaitForMessage(THREAD_POOL_PARAM_T *ctp);
	static THREAD_POOL_PARAM_T* ContextAlloc(THREAD_POOL_HANDLE_T *handle);
	THREAD_POOL_PARAM_T *pTh=0;
	return(pTh);
THREAD_POOL_PARAM_T* Comm::ContextAlloc(THREAD_POOL_HANDLE_T *handle)
	void* pTh=0;
	int fd;
    fd= open("/dev/mydev", O_WRONLY);
    return ( (THREAD_POOL_PARAM_T*)pTh);
Bye,
Mario
RE: Resource manager using thread pool in C++
Re: RE: Resource manager using thread pool in C++
Thank you both very much for such a quick reply.
Follow the "complete" code of what I have until the moment (there's still much to do).
About returning a void pointer, I've just did the same as the thread pool example in the Get Programming with QNX
Neutrino guide does.
#define CAN_SERVER_PATH "/net/..."
//  Global variables
//  Thread pool lifecycle functions
//  Context manipulation functions when thread is created and killed
    if(comm_server->can_coid == -1)
        //  Failed to connect to CAN server
        //  Return error
    //  Initialize values;
    comm_server->comm_rcvid = -1;
void Comm::ContextFree(THREAD_POOL_PARAM_T *param)
    CommServerStruct *comm_server = (CommServerStruct *)param;
    delete comm_server;
//  Function to block waiting for a message from client
    //  Cast pointer
    CommServerStruct *comm_server = (CommServerStruct *)ctp;
    //  Blocks waiting for message
    MsgReceive(comm_chid_, comm_server->msg, sizeof(comm_server->msg), NULL);
//  Message parsing function when unblocks with received message
int Comm::ParseMessage(THREAD_POOL_PARAM_T *ctp)
    //  Cast pointer
    char return_message[16];
    //  Pass the message over to CAN server
    MsgSend(comm_server->can_coid, comm_server->msg, sizeof(comm_server->msg), return_message, sizeof(return_message));
    return 1;
//  Communications set up and start
int Comm::InitComm()
    if((comm_chid_ = ChannelCreate(0)) == -1)
        //  Could not create Channel, insert error code
        return -1;
    //  Set up the thread parameters for the threads that will populate the pool
    pthread_attr_t *t_attr;
    pthread_attr_init (t_attr);
    //  Set up the thread pool parameters
    thread_pool_t    *tpp;
    memset(&tp_attr, 0, sizeof (tp_attr));
    //tp_attr.handle = (void *) 0x12345678;  // passed to contextalloc
    tp_attr.unblock_func = UnblockFunc;
    tp_attr.context_alloc = ContextAlloc;
    tp_attr.handler_func = ParseMessage;
    tp_attr.context_free = ContextFree;
    tp_attr.lo_water = 2;
    tp_attr.hi_water = 6;
    tp_attr.increment = 1;
    tp_attr.maximum = 10;
    tp_attr.attr = t_attr;
    //  Create a thread pool that returns
    tpp = thread_pool_create (&tp_attr, 0);
    if (tpp == NULL)
        //  Could not create thread pool
        return -1;
    if (thread_pool_start(tpp) == -1)
        //  Could not start thread pool
        ChannelDestroy(comm_chid_);
        //sleep (3000);
        return -1;
    //  If it gets here, thread pool is up and running
    return 1;
And yes, I did assume it was more of a language problem.
QNX base it's guides and manuals all in C language.
Could you please give me some directions on how to deal with this C++ Method vs C function callback assignment?
About returning a void pointer, it's different from C than C++: in C++ type checking
is much stronger that in C: You must return the type You've declared explicitly.
About Your code, You miss the most important thing: class declaration :-)
Mario
I was giving a further read in the resmgr_context_t structure, and I've realised that I can use it's own attribute IOV
to return the values that I need.
About class declaration, it comes in the header, that I did not posted (see below).
#ifndef CMS_COMM_H_
#define CMS_COMM_H_
#include <stdio.h>
#include <stdlib.h>
#include <errno.h>
#include <string.h>
#include <fcntl.h>
#include <sys/types.h>
#include <sys/stat.h>
#include <sys/neutrino.h>
#include <sys/dispatch.h>
class Comm
//  Data structure
public:
    typedef struct CommServer
        //  How long without CAN reply for killing itself
        int timeout;
        //  Receive ID for it's COMM server role
        int comm_rcvid;
        //  Channel ID for it's CAN client role
        int can_coid;
        //  Message information
        char msg[6];
        //int msglen;
    } CommServerStruct;
private:
    THREAD_POOL_PARAM_T * ContextAlloc(THREAD_POOL_HANDLE_T *handle);
    void ContextFree(THREAD_POOL_PARAM_T *param);
    THREAD_POOL_PARAM_T * WaitForMessage(THREAD_POOL_PARAM_T *ctp);
    //  For future versions
    void UnblockFunc(THREAD_POOL_PARAM_T *ctp);
    int ParseMessage(THREAD_POOL_PARAM_T *ctp);
    int comm_chid_;         //  Channel ID
    int can_chid;
public:
    int InitComm();
#endif
Sorry, a bit of repeated comments, as I'm still filling up the whole thing, but got stuck in those initial issues.
Thank you very much for the help anyway!
But still remains the question about setting the thread pool functions, since in C++ reference to callbacks are not as
straight-forward as in C.
Hi, some trouble with Your sources: to use call backs, You must use static methods,
but in such case, You cannot access class members...
Maybe You should think to switch back to good old plain C :-)
Anyway, I've attached a example source: maybe it can help  (I've not test it)  :-)
Bye,
Mario
Attachment: Text fuffacpp.cc 6.79 KB
Thank you very much, Mario.
Will give a thorough study into it.
Cheers!
